Fuse for trunk Actuator
Old Dec 5, 2019 | 06:38 PM
LindaGilb's Avatar
LindaGilb
Default Fuse for trunk Actuator
Trunk Actuator fuse
Old Dec 5, 2019 | 06:41 PM
LindaGilb's Avatar
LindaGilb
Default Fuse for trunk actuator
Where is the fuse for my Trunk Actuator for my 2007 LS 460? I do not have power going to my new trunk actuator..
Old Dec 6, 2019 | 04:57 AM
Thegamemhb's Avatar
Thegamemhb
Even i am having some problem with the trunk .. what are you facing ?
The fUse is in the trunk fuse box
Old Dec 6, 2019 | 06:06 AM
Thegamemhb's Avatar
Thegamemhb
Number 12 PTL 30 amp if that is what you are looking for
Old Dec 17, 2019 | 06:18 AM
Thegamemhb's Avatar
Thegamemhb
Any update
Old Dec 17, 2019 | 05:50 PM
miket000's Avatar
miket000
If your trunk won't open by pushing the buttons... Disconnect the negative side battery cable for 5 minutes. Then reattach it. The truck will usually open after that. The trunk lock mechanism usually needs to be replaced $300 or so for the part. It is a fairly common issue on the ls460.
Old Dec 19, 2019 | 08:25 AM
DavidinCT's Avatar
DavidinCT
Also check your battery voltage. If the battery is going, screwy things happen.
Old Dec 19, 2019 | 11:47 AM
Thegamemhb's Avatar
Thegamemhb
I dont know about lindgilb's problem but i feel my trunk switch is gone bad as it is a very common issue and i replaced my battery just one month back now i am confused if i should go for a used part or buy a new one any idea if this problem was similar in 2011 2012 models i am asking this because then i will look for the later model part and replace it with it
rhill100
Oct 15, 2018 07:41 AM
Alexbenz
Feb 9, 2017 12:55 PM
lamontp71
Apr 18, 2016 07:58 AM
nuck
Feb 2, 2015 12:26 PM
SilverLS400
Jul 31, 2002 08:42 AM
