how much engine vibration do you feel?
Old Oct 26, 2019 | 08:29 PM
jdanielca's Avatar
jdanielca
Default how much engine vibration do you feel?
Hey guys at stop lights or whenever, how much engine vibration do you feel?
Old Oct 27, 2019 | 03:45 AM
Thegamemhb's Avatar
Thegamemhb
08 ls460 . 6-10%
Mine is smooth like butter sometimes it feels the engine is not on
Old Oct 27, 2019 | 05:20 AM
dlbuckls10's Avatar
dlbuckls10
My LS is ten years old and still smooth when idling.
Old Oct 27, 2019 | 06:31 AM
jdanielca's Avatar
jdanielca
yeah thing is i dont know how smooth is smooth.... am I supposed to feel something or nothing at all.
Old Oct 27, 2019 | 06:50 AM
Dave144239's Avatar
Dave144239
I feel nothing at all.
Old Oct 27, 2019 | 06:57 AM
Thegamemhb's Avatar
Thegamemhb
I guess almost feel nothing
Old Oct 28, 2019 | 11:47 AM
SolarCzar's Avatar
SolarCzar
I recently began to notice that when the vehicle is in Park, I'll get an occasional "shudder", but it's slight and I never feel it at Stop lights or the like. Otherwise it's smooth...
Old Oct 29, 2019 | 03:36 PM
nickderosa's Avatar
nickderosa
super quiet and almost no movement. i use the HOLD feature for stoplights and it feels like i'm sitting on the couch at home
Old Oct 29, 2019 | 03:59 PM
It should be almost imperceptible.
Old Oct 30, 2019 | 04:10 AM
nsaldanh's Avatar
nsaldanh
What is the car's RPM when you are at a stop light with the car idling? If under 700 RPM then turn on your seat cooler/warmer or the and that will boost the RPM to about 650 - 700 RPM. I had a 2012 LWB and that car would have a slight shudder/vibration when the seat fans or air conditioner compressor were off. Lexus apparently designed the car to have both of them always on with the car idling at 700 RPM. at 700 RPM the vibration went away.
Old Oct 30, 2019 | 04:25 AM
ALK's Avatar
ALK
I have read the ECU data. The idle rpm is dictated by ambient and coolant temperature.
Old Oct 31, 2019 | 06:36 AM
nsaldanh's Avatar
nsaldanh
and also electrical load on the system per a service advisor at Lexus.
Old Oct 31, 2019 | 07:05 AM
jrmckinley's Avatar
jrmckinley
Can you elaborate a bit on the "coolant temperature" comment and how that impacts the car at idle? Is it strictly RPM - meaning the RPM would fluctuate based on this... I didn't see this thread and just posted something about a slightly different "feeling" at idle when my car is in "drive" instead of neutral, park, or reverse. RPM's are staying consistent but the experience in the cabin is a bit different in "drive" at idle.
Old Oct 31, 2019 | 12:19 PM
jdanielca's Avatar
jdanielca
mine looks to be under 700 and nothing i turn on seems to make any sort of change
Old Oct 31, 2019 | 05:02 PM
3GSShoe's Avatar
3GSShoe
LS's should all be smooth at idle. This is a little subjective but overall, there should not be vibration. Many LS's require the AC compressor to be running to idle normally. Lexus confirms that this symptom is normal.
