Climate settings
Old Jul 4, 2019 | 08:44 AM
caspittal's Avatar
caspittal
Default Climate settings
Ever since the cabin filter was changed and reset, I have to manually set the climate settings when I start the car. How can I change this to be automatically set?
Old Jul 4, 2019 | 09:11 AM
colfax's Avatar
colfax
I had the same problem when I attempted to change the cabin air filter a while back.
It turned out I had not properly refitted the plastic cover pieces, I thought they did not really matter but apparently the car senses the slightest not exact fitment.
Try removing and carefully refitting the retaining plastic pieces......
edit: is it possible you damaged the mechanism by not insuring the air circulation flap was in the correct position?
Old Jul 4, 2019 | 09:27 AM
caspittal's Avatar
caspittal
Thank you for the quick response. I’ll have to check with the hubby as he was the one that changed the filter. I’ll have him try your suggestion. Thanks again.
Old Jul 4, 2019 | 12:28 PM
mdpresco's Avatar
mdpresco
https://www.clublexus.com/forums/ls-...c-problem.html
Look at this link. It will help.
USCRugby
Jun 16, 2023 08:22 AM
lexman52
Apr 23, 2018 06:03 AM
The1Ghost
May 30, 2011 09:38 AM
saudiboy
RX - 1st Gen (1999-2003)
Jan 19, 2008 11:30 AM
keviner808
May 4, 2007 03:27 AM
