Has Anyone Replaced their Water Pump?
Old Jun 14, 2019 | 11:33 AM
sha4000's Avatar
sha4000
Originally Posted by texas008
might be ~6 hours, i was taking my time.
I bought the no-brand radiator on ebay and the tab does not align with the radiator bracket, so I have to cut and drill the tab to fit it in.
I also removed the front bumper to have easy access, which turned out to be unnecessary. Therefore i spent quite a lot of time
now after 3 years and 50k miles, the reservoir tank needs to be filled half quart of coolant every 4 months.
might need to replace radiator again. this time I bought the OEM radiator.
How hard was it to remove the bumper? Specifically from around the headlights.
Old Jun 17, 2019 | 04:04 AM
texas008's Avatar
texas008
not very hard, just need to remove screws/pins around each wheel well, and pins between the bumper and under-carriage panel.
there might be some youtube video on this.
Old Jun 17, 2019 | 03:49 PM
sha4000's Avatar
sha4000
Thanks, I ask because I had all the screws out at one point and felt like I would tear the bumper with the amount of force I was applying to get the clips around the headlight to release. I eventually just left it alone but would like to revisit it someday.
Old Jun 20, 2019 | 03:18 PM
Dolph1's Avatar
Dolph1
As a result of this thread I was motivated to remove my engine covers for the first time so I could check my water pump for leaks. I was unable to get a good look as the engine air intakes (may not be the technical term)were blocking my view. Roadfrog - you removed those engine air intakes to get such a great picture I assume? Was it difficult?
Removing the covers also gave me the opportunity to see a huge pile of leaves and sticks in front of my radiator - definitely check your car for this - see pictures. I saw this mentioned in an old thread but had subsequently forgotten about it. Also found an engine cover clip and cigarette butt amongst those leaves!
One last question for those who remove the engine covers, is mine missing something on the underside in the corner closet to the driver seat? Looks to me like something broke off there.
You can reach your hand in there if you don’t have Popeye forearms. I also used a shopvac.
Pile I removed.
Did something break off here? Corner closet to the drivers seat
Old Jun 20, 2019 | 07:54 PM
joedaddy1's Avatar
joedaddy1
Originally Posted by RussLS460
I'm at 105K on the original water pump......how is this possible?
Don’t ask me..
but i’m a type of person that’ll get something fixed within days. Like someone above mentioned, the water pump could be seeping for years and 20k miles.
i replaced mine within a week on the first signs.
cant afford the unexpected downtime.
Lexi66
May 18, 2016 07:28 PM
letter7987
Aug 14, 2015 08:11 PM
kur1j
Nov 5, 2014 10:54 AM
sorka
Jul 26, 2008 11:47 PM
