Brake Drama
I think the bottom line is that this has always been a collaborative forum, responses like the OP got above are out of line and outside of the character of this forum. We've always had a remarkable lack of that kind of stuff. Hopefully that isn't a trend.
I apologize for that response on behalf of the forum OP.
The following 11 users liked this post by SW17LS:
ALK (05-12-19),
Chuckinnj (05-12-19),
fwhomeboy (05-12-19),
LS460Crown (11-13-19),
mbarron37 (05-12-19),
and 6 others liked this post.
BTW C1241 could be the reason . Its triggered if there is a voltage drop . Meaning battery
Check attachment.
Thanks man. This is what I have been looking for. I guess my next step is to pick up a Techstream setup so I can bleed the brake system and work on diagnosis. I didn’t realize Techstream would be required for a simple brake bleed.
rosenthal (09-16-22)
Ok, here’s another quick question while I’m checking this stuff out. I’m not sure if this is normal or not, but my car has always done this sort of priming as long as I have had it. I have removed some of the engine plastic prices and the brake actuator is definitely the culprit of the noise.
Is this normal?????
Is this normal?????
Not normal....
Is this normal?????
https://youtu.be/tv_U82Gjp-s
Is this normal?????
I echo the sentiments of others about the unnecessary comments in this thread.
I too have an 07 that hasn’t had the
actuator replaced with 109k miles. It seems as if these just go out indiscriminately which is unfortunate.
I am very interested in hearing about your journey through this process.
edit: did you ever feel like your brakes didn’t have enough bite to them, not in the process of braking but at a light w/o brake hold engaged it feels like my brakes slip sometimes like I need to put more pressure than I normally do in a car, my brakes and rotors have less than 5k miles.
Is this normal?????
Is this normal?????
Is this normal?????
Is this normal?????
icon901 (06-12-19)
The brakes typically feel fine. I can say that I feel they need more bite, however I have hear some strange noises from time to time.
In the video above, all that was done was open the driver-side car door. The car had not been drove for roughly 24 hours.
That was my thought as well. I only took a short video, but after the extended “priming” noise it will continue the short primes every few 7 to 10 seconds for a little while.
icon901 (06-12-19)
