No sound from radio
I recently after starting my car (2011 LS460) discovered that no sound was coming from my radio. The dealer suggested that I turn on the power, but not start the car by pressing the on/off button with my foot off the brakes. After doing that I was told to hold the radio on/off button for several seconds to see if this fixed the problem. It did not. I was told that my amplifier might have to be replaced. Took the car in to have service check it out. There was no problem with the amplifier. After further testing, service tech found that the CD player worked just fine with good sound coming out. With this they concluded that it was just my radio that bad and needs to be replaced. Has anyone else had this problem and found a solution other than replacing the radio?
Did you confirm what they concluded? Did you play a cd? Did you try playing a MP3 file or USB file through it? Do you have Satellite (Sirius XM)? Is it possible that your antenna became dislocated somewhere?
Did you read the FAQ thread? Why not?
Here - go to the last page:
https://www.clublexus.com/forums/ls-...mp-repair.html
