Pinned my Jack!
Old 03-25-19, 08:07 AM
Tlutrick
Tlutrick's Avatar
Default Pinned my Jack!
So had my LS460 on jacks for better of a week, doing the laundry list of maintenance items. When I completed my work and went to take it down off the jack stands, the car went all the way to the ground and pinned my jack. Scared the hell out of me. Luckily, my neighbor was home and had another low profile jack to get under a side and lift it to remove the jack. So at this point, I am racking my brain to think what I did wrong. Then all I could think of is that the car has air suspension and maybe they were the plaintiff. Started the car and waited, slowly but surely, the car came back up to normal height. Whew!
I'm hoping someone can save me from screwing this up next time it has to go on jacks, by telling me what I did wrong or need to do.
Thanks
Old 03-25-19, 08:37 AM
Kansas
Kansas's Avatar
The owners manual says to turn off the height control before raising the vehicle - page 494 of the online owners manual at https://drivers.lexus.com/t3Portal/d...f/OM50738U.pdf
mambo619 (03-25-19)
Old 03-25-19, 09:00 AM
Tlutrick
Tlutrick's Avatar
So I missed that one, thanks. So read the manual and does not say "How" to turn it off. Is it simply pressing the High Height button and leaving it on?
Old 03-25-19, 12:45 PM
1WILLY1
1WILLY1's Avatar
yea the air struts "air out" all the time when you jack the car, at least mine do
Old 03-25-19, 02:17 PM
Tlutrick
Tlutrick's Avatar
So how do you turn off the height control?
Old 03-25-19, 02:28 PM
jdanielca
jdanielca's Avatar
i think they mean set height to normal or turn height high off.
Old 03-25-19, 07:19 PM
sha4000
sha4000's Avatar
Thanks
It just means make sure the height high button is switched off and don't start the car while it is on the jack stand because the suspension will try to correct the height of the wheels when they are hanging. This is why the car went to the ground once you removed the stands.
Old 03-25-19, 08:36 PM
Tlutrick
Tlutrick's Avatar
That’s the problem. You have to start the car on jacks when doing transmission fluid changes, in order to get to the right temp. The time it takes to jack the vehicle and get it level, once it reaches the right temp is too time consuming
CAK 500
04-03-18 08:34 AM
ilexusnow
10-04-17 02:48 PM
jasone36
11-05-15 04:45 PM
flipside909
IS F (2008-2014)
03-20-09 12:47 PM
Xenon9
08-02-07 01:53 AM
Quick Reply: Pinned my Jack!
