LS460 brake actuator part number, final answer.
Old Aug 25, 2018 | 03:20 PM
Legus's Avatar
Legus
Default LS460 brake actuator part number, final answer.
I have done a lot of searching these forums and I have found 4 part numbers for my brake actuator can someone please help me out which one am I supposed to get? Some say the 600 brake actuator, there is a new and old one for that. Is there an aftermarket one? Can i use one from another toyota? I believe the last owner replaced it with a junkyard part as it failed again. Very scary as if I do not fill the brake fluid every few days my brakes will stop working. I want the one that won't break again whatever cost!
Old Aug 25, 2018 | 03:26 PM
jdanielca's Avatar
jdanielca
Originally Posted by Legus
I have done a lot of searching these forums and I have found 4 part numbers for my brake actuator can someone please help me out which one am I supposed to get? Some say the 600 brake actuator, there is a new and old one for that. Is there an aftermarket one? Can i use one from another toyota? I believe the last owner replaced it with a junkyard part as it failed again. Very scary as if I do not fill the brake fluid every few days my brakes will stop working. I want rhe one that won't break again whatever cost!
isnt this covered by toyota recall?
Old Aug 25, 2018 | 04:16 PM
Legus's Avatar
Legus
Unfortunately my car is not, which is the reason I'm asking. It is over 10 years old so the warranty is not available. As far as I know the last owner also replaced the actuator (with a junkyard part), so I don't believe this models VIN was listed under the recall TSB.
Old Aug 25, 2018 | 04:50 PM
jdanielca's Avatar
jdanielca
listen my car is also 10 years old but this is a safety recall so.. have you like checked properly... as far as I know safety campaigns never end no? someone else chime in please.
Old Aug 25, 2018 | 05:23 PM
Dave144239's Avatar
Dave144239
Here's the official warranty info.
Old Aug 25, 2018 | 07:25 PM
UDel's Avatar
UDel
Call Lexus corporate and fight for it, it never hurts to try a couple times before shelling out all that money. This is a safety issue and a very expensive repair, they should not be cutting off or denying this repair to customers.
Old Sep 22, 2018 | 03:25 PM
Legus's Avatar
Legus
Thanks for the concern fellas. Unfortunately the reality is that corporate will do whatever they can to avoid dealing with stuff like this. They are not lenient about it. After 10 years or 140000 miles these recalls are no longer available for service. If the part fails within this time span it is considered defective, but if it fails after its just considered normal high mileage maintenance. There are technicalities, I know if I bought the car CPO I could've gotten the recall serviced, also if I signed up by a specific date I could've made the extended recall only thing is that specific date was while it was sitting in the last owners garage like a month before I bought it.
THANK YOU. I moved at the beginning of this month otherwise I would've been on here to thank you sooner.
I found the part cheaper than anywhere else (still $1000) on discountpartsmonster, installed no issues.
Old Sep 22, 2018 | 03:42 PM
Julez's Avatar
Julez
How many labor hours did installation take?
Old Sep 22, 2018 | 06:33 PM
UZ214's Avatar
UZ214
there are few actuators on the market, I think there are 5 if I recall correctly ; mine was making noise the brake bleed fixed the issue, it still clicks here and there very lightly but its not as noisy as before and I think all LS460s do it. My lexus dealer wanted 3200 for it installed included when I was almost gone change it. with the latest part. They refused to put in any new (older version) of the actuator. I still have 3 years and 35k miles to go for lexus 10 year 150k warranty if it fails so though why not wait. I think the labor is about 1.5 hrs.
Old Sep 22, 2018 | 07:54 PM
joedaddy1's Avatar
joedaddy1
Not a safety recall.
it was a warranty extension.
i think we all should just assume this is like a timing belt.
Lets assume 8-10 year life span 80-100k
$3000. Damn. Good luck all
Old Sep 22, 2018 | 11:02 PM
DriverSS's Avatar
DriverSS
In Feb of 2016 I had this issue with my '08. Found it quite curious it was a known issue then and not covered AND that original part was not even available because they were all being replaced with LS 600 Actuators (per the parts guy)... no joy, repair was like 4 hrs, part was over $3,000. This year I stumbled across the "Warranty Enhancement Program - ZLG", noticed it stated "Lexus will begin to notify owners in late April, 2016".. well Lexus, I had the repair done 2 months prior, I even called you about this exact thing, where the @$#$@# was my Letter? I called the number, sent copies of my paperwork and within a week I had a check for the repair.. 2 years later, the way it should've been handled back in Feb of '16.
smdh....
The PN used on my '08 LS 460 was "44050-50170 Actuator Assy, BR"
As I work in the industry (and asked for it) I was able to get jobber rate and that knocked nearly $1K off the cost of the part. YMMV...
Old Sep 24, 2018 | 09:42 AM
JH48's Avatar
JH48
I got my previous 2010 LS460 replaced by dealership with no cost. it tooks them 2 weeks to ship from Japan to US. 1 week to do the work.
Old Sep 25, 2018 | 12:27 PM
1NSIGHT's Avatar
1NSIGHT
My brake actuated failed and the dealer took care of it. I contacted corporate and they fixed the car no charge.
This was on my 07 with 100k plus miles at the time it failed.
Old Sep 26, 2018 | 04:46 PM
Legus's Avatar
Legus
Did you buy it from that dealer?
Old Sep 26, 2018 | 04:49 PM
Legus's Avatar
Legus
This was not a safety recall????? Wait a minute.
My brakes totally failed in traffic. How is this not a safety recall?
