Front facing or 360 cams?
Anyone installed front facing or 360 cams? those that go on the grllle some place or under the side mirrors... things are tight here could make my life much easier..
I don't know of an aftermarket kit to get a front camera view for the 2007 LS, let alone side or 360 views. I installed the BeatSonic IF-04EP kit that provides Nav Bypass and mirrors my iPhone, but also enabled me to install a front camera. It works really well. You can check out the details on this thread.
https://www.clublexus.com/forums/ls-...nt-camera.html
Do you know if there's a way to enable the rear view cam when not in reverse? When I'm parallel parking I hate that it turns off just b/c I inch forward a bit. In most German cars once engaged it stays on until you go over 4mph or go to Park.
I should clarify my original reply. AFAIK, there are no aftermarket kits that will display front and side camera views on the LS's Nav screen, other than what I have installed with the Beatsonic kit. However, if you are OK with a secondary display in your vehicle (mounted by the headlight stalk or on a DVD head unit like Pioneer etc), then there are kits available to install side mirror and front cameras.
https://www.qualitymobilevideo.com/c...r-cameras.html
comotiger
Aug 8, 2020 08:49 PM
SigEpGX460
GX - 2nd Gen (2010-2023)
26
Dec 31, 2019 05:42 PM
Ingelsgard
Mar 10, 2017 08:24 AM
