Grom
Old Jun 30, 2018 | 06:10 PM
joedaddy1's Avatar
joedaddy1
Originally Posted by dphennis
I installed the Vline today Lexus LS 460 2007-2009 (without Self Parking Assist, Navi) and for some reason, it is not showing up on my screen. I did everything it said to do and I watched the video on how to install it. I did not remove the Nav screen but instead reached behind it to plug in the blue wire. All the plugs were plugged back in. When I hit disc to HDD it just shows a screen that looks like its reading a USB drive (says file name - Vline) So I know it's seeing the Vline..... Problem is I cant see it!!!! I messaged Grom but I won't get an answer until Monday afternoon. Any info would be greatly appreciated.
I just installed mine today. Same model. Do you have a screen shot?
try disconnecting the video cable and reinsert. I had the issue for a sec.
Old Jun 30, 2018 | 06:23 PM
dphennis's Avatar
dphennis
Old Jun 30, 2018 | 06:30 PM
joedaddy1's Avatar
joedaddy1
Hmmmm... just making sure.. you connected the blue cable to the back of the display right?
im sure you tried going to FM then to cd changer 2.
i get to your screen if I press SCAN button on the radio about 3 times to change sound like bass and treble. To get back to GROM, I have to press cd/aux button again. And then it goes back to android screen
Old Jun 30, 2018 | 06:31 PM
dphennis's Avatar
dphennis
Can the cable from Grom to nav screen only fit in one hole?
Old Jun 30, 2018 | 06:35 PM
joedaddy1's Avatar
joedaddy1
The middle one
ideally yes. Did it snap in? It’s the blue on in the middle. Here is a screenshot of the video I made to see what’s in the back.
Did you jam it in the first slot instead?
I bet even you disconnected the DisplayPort connection at the grom, you would see the same screen you are seeing
Old Jun 30, 2018 | 06:39 PM
dphennis's Avatar
dphennis
When I disconnect Grom nothing changes. It did snap in though. I am gonna have to try again. I wanted to avoid pulling the nav screen out.
Old Jun 30, 2018 | 06:42 PM
joedaddy1's Avatar
joedaddy1
Can you use your video function on your cell phone to see everything snapped in the correct place? That’s what I did. I also didn’t pull out the display.
Also, take the DisplayPort cable out of GROM and replug. Mine wasn’t in all the way.
I literally installed mine 2 hours ago.
If replugging the DisplayPort doesn’t work. Perhaps that cable is not working. I say this because I can clearly see Vline on your screen, so the other connection seem to be working
Old Jun 30, 2018 | 06:45 PM
dphennis's Avatar
dphennis
So you think it's the connection into the nav screen?
Old Jun 30, 2018 | 06:48 PM
joedaddy1's Avatar
joedaddy1
yes. Because I see VLINE in your radio screen.
If your reconnect the video cable again and then pressed FM then Cd changer button twice... with no android popping up. Then I must wager $5 that it’s ur video cable.
even worse no signal to video port in the grom unit itself. Let me go home in couple of hours and test. I’ll post a video on what I would do to get to you screen to Android screen.
Old Jun 30, 2018 | 06:49 PM
dphennis's Avatar
dphennis
Thank you so much!
Old Jun 30, 2018 | 07:02 PM
dphennis's Avatar
dphennis
Does your video end look like this? Looks like it's missing prongs
Old Jun 30, 2018 | 07:04 PM
joedaddy1's Avatar
joedaddy1
no. That’s not video. The long rectangle one pointy side is your video DisplayPort video
Old Jun 30, 2018 | 07:10 PM
joedaddy1's Avatar
joedaddy1
DisplayPort
Old Jun 30, 2018 | 08:38 PM
joedaddy1's Avatar
joedaddy1
check your PM.. i sent you a link to my video.. it's too big to post here.
Old Jul 1, 2018 | 07:55 AM
dphennis's Avatar
dphennis
So I checked the back of nav screen and I did put the wire in the right hole. I can get to the Vline screen but then when I hit disc twice it just takes me back to Vline screen. It never navigates to the grom home screen. Everything is in the right spot but it's not reading it. I will say that when I went to pull out the blue plug from the nav screen there was not one there. I read in the Vline manual that if one is not already there just plug in the male end and leave the female end hanging. I'm stumped
