ECM Replacement
Old Feb 12, 2020 | 01:11 PM
fooldall1's Avatar
fooldall1
Originally Posted by hfowler
Update... I finally decided to just take my car to the dealership. They found a loose connection. I still had to pay for the 2 1/2 hours of labor they took to find the problem for a total of $636 but at least that's better than the $2400 to $2600 I was quoted for a new ECM and labor for programming and installation. I'm usually not a fan of paying the dealership service price but I think when it comes down to computer issues, it's best to go with their experience.
Did they show you where the :loose" connection was? I'd like to know, that and all the ground connections. Did they just re-seat the connectors? I'm having a similar situation with my vvt/cam position sensor(s) and I want to make sure that I have all the grounds/wires securely connected and checked. Thanks!
Old Dec 27, 2021 | 03:33 PM
Parrokeete's Avatar
Parrokeete
Default ECM notice on dash
I have been told that my 2007 LS 460 needs a new Electronic Control Module, which is about $1500- $1800 new. Has anyone had any luck replacing their computer system with a rebuilt and reprogrammed ECM?
A month ago I had the brake actuator and the 2 high pressure fuel pump seals replaced a 2 weeks ago I had a remote start installed and a week later I installed a new set of tires. 5 days ago I got a ecm and check engine light on the dash, also the transmission would not shift anymore and the traction control notice came on the dash and will not close off. The parking brake started getting stuck on also. Mechanic will look at it in a few days and I was wondering if there is a reset or will I end up having to replace the ecm?
Old Dec 27, 2021 | 04:13 PM
Check the trunk for water intrusion
Old Dec 27, 2021 | 07:03 PM
Parrokeete's Avatar
Parrokeete
I'm definitely upset over cost. Unfortunately they were my last resort since I had 2 independents that could not find the loose connector. I'm even more upset that I now also need to find someone to replace my front control arms at a reasonable price. I was quoted $3600 by the independents that I don't feel I can trust after this ECM issue and $5000 at the dealership.
That’s a lot of cost for control arms. I got both left and right front lower and stabilizer bars and front shocks installed for $900
Old Dec 27, 2021 | 07:04 PM
Parrokeete's Avatar
Parrokeete
Ok, thanks, I’ll check the trunk for water. Wow I think this could be 100% the problem because I just ran the car through the car wash and got stuck on the broken car wash track for about 10 minutes but the water kept flowing and I also saw some water in trunk information posted before I bought the car but had forgotten it. I have been out of town a few days and will look into it tomorrow and will give an update.
Bobk528
RX - 1st Gen (1999-2003)
Dec 29, 2021 09:10 AM
Kenski
Dec 15, 2015 07:13 AM
MrApex
37
Oct 25, 2015 12:44 PM
LadyLex350
Mar 10, 2013 01:08 AM
mikegbuff
Jan 25, 2013 03:46 PM
