USB compatibility
Old Oct 15, 2018 | 04:08 PM
sha4000's Avatar
sha4000
I have had macs going all the way back to a tangerine clamshell and this is the reason why I would not consider an iphone. Just too restrictive and once your locked in for years it's too hard to crossover. I don't care how seamless the experience is or how great the quality of the files.
Old Oct 15, 2018 | 05:09 PM
DriverSS's Avatar
DriverSS
I've had Macs longer than that. As to the too restrictive issue, its not a thing for me. I knew it going in. Was fully aware. And no way I'd go Android (spyware masquerading as a phone).
Old Oct 15, 2018 | 06:38 PM
Seejay's Avatar
Seejay
I am so glad to see that we are all in agreement.
Old Oct 20, 2018 | 11:53 PM
RX350FStev's Avatar
RX350FStev
I try format my 16 gb flash drive -fat 32 and 32 bit , then create both file name DisplayoffImage And StartupImage (Case-sen) and a music folder, picture save as Jpeg format, then plug into my car , music working ,but no image ,
when I go in to the transfer screen , It only show me the no option ,as picture in attachment ,
and ,I just want have me little son picture in the screen lol
so I just want to know it is anyway I can do it ,or I need to bring it to dealer to check
or the image resolution is too big ?I set it as 1024 *680
Old Oct 21, 2018 | 08:01 AM
comotiger's Avatar
comotiger
The file size is too big. Make it smaller. Also, on USB stick, have only those two folders for Startup and Displayoff, and try again
Old Oct 21, 2018 | 11:06 AM
FatherTo1's Avatar
FatherTo1
Here is a thread that goes over it again. I recall comotiger has referenced the link before for others too. I got it to work in the past but do not recall if resolution mattered. I want to say the system just scaled the resolution automatically. It definitely works though and does not require a trip to the dealership. I won't have my car back until Monday and will confirm settings tomorrow.
https://www.clublexus.com/forums/ls-...-ls460s-2.html
Old Nov 3, 2018 | 08:09 PM
FatherTo1's Avatar
FatherTo1
Just wanted to report back that StartupImage works for me with photos ranging from 3.5 MB to 7.8 MB. Resolution of photos is 4385x3132 and did not require me to resize anything, the LS can scale everything to fit accordingly.
Old Nov 16, 2018 | 09:51 PM
FatherTo1's Avatar
FatherTo1
Originally Posted by Dolph1
If you have all that Apple lossless get yourself a 5th gen iPod that has been modded. You can find ones on eBay that have flash memory with up to a tetrabyte of storage. Don’t go to lossy! The 5th gen iPods seem easy to update yourself as there is a good video on line. It is on my to do list to buy a used one and modify it myself.
Dolph1, why do we need a "modded" iPod? Modded with what, a modified OS? I don't quite follow here. I need to find some ancient media, aka CDs, to test if I can differentiate between WAV and 256Kbps streaming over BT on the ML system. If so, then I want to look into getting an iPod for lossless audio. There is so much information across many threads and, if I understand things correctly, the best/easiest option for lossless audio appears to be an iPod ALAC connected by USB, yes/no? This setup bypasses the iPod's DAC and equalizers and let's the ML decode the audio bitstream, right?
Old Nov 17, 2018 | 12:04 AM
Dolph1's Avatar
Dolph1
The modded refers to the size of the hard drive. The largest capacity iPod made had a 160gb hard drive, which is not large enough for people with very large music collections that also happen to prefer lossless. I tried to contact ML directly to find out if the decoding of music on Apple products is happening in the ML head unit (preferrred) or the Apple product. If it happens in the Apple product the 5th generation is the better iPod to get your hands on as they are considered to have the best DACS of all the Apple products. Apple did not like digital leaving the ipod, most audio products connected to iPods were pulling analog from the iPod. I had a response from the US Home Audio Division of ML that redirected me to the ML Automotive Division. I never heard back from ML automotive so I have just sent a chaser but am not holding my breath. Here are the questions I put to ML, I didn’t even attempt to pose these questions to Lexus as I do not think they would be able to answer them.
Dear ML,
... I will share the answer on the ClubLexus LS forum so you will really be answering this for the wider Lexus audiophile community. 1) When using the USB connection to connect an iPod/iPhone/iPad does the Apple DAC get bypassed in that digital is passed directly to the ML system for processing? 2) What brand and model of DAC is used in the 2013 Lexus LS ML system? To the extent these answers apply to the 2014-2017 Lexus LS460 ML Reference system as well can you please confirm as the car remained virtually unchanged between the 2013-2017 model years.
If I ever get a response I will post it to this thread.
Old Dec 13, 2018 | 06:58 AM
gs350fan's Avatar
gs350fan
One last thing, Make sure your USB is Formatted as an MBR partition and not GPT. This made it work for me. I used a USB that was an OS installer. GPT will not be recognized.
Old Feb 1, 2021 | 10:37 AM
tle99104's Avatar
tle99104
Hi, my Lexus ls460-2013 cant play usb, push media button, it appears disc and BT audio only, usb between them do not light up. Replace by other usb which works fine in Lexus is250c and still do not work. CD and dvd work fine. no have ipod so no test, Can some one help? does usb have it own fuse? Appreciate your help',
tle99104
Old Feb 1, 2021 | 04:27 PM
Seejay's Avatar
Seejay
tle99104
Try formatting a known working USB stick on a Windows computer to FAT32 (that is the default setting), then copy a MP3 file to it. Plug it into your car's USB port and see if the USB tab lights up on the audio screen. If not, then it is possible that a fuse blew (Toyota probably fuses this since it is 5 vdc @ 1A) or there is a connection failure (wiring or connector) of some sort.
rpe94
Jun 5, 2022 02:49 PM
andyville
22
May 15, 2021 04:03 PM
abbeyrd
Jul 9, 2017 03:34 PM
wnyjazz
Jul 29, 2016 12:25 AM
sharmila19
Apr 5, 2015 08:00 PM
