2009 Lexus LS 460 AWD front clearance seems high
I recently purchased 2009 Lexus LS 460 AWD with air suspension and noticed the front clearance is a bit higher than the rear. Is that normal and can it be adjusted?
samtes (11-30-17)
Try the normal position, height button (rises the car) and then check the clearance. Also check your LS to see if its leaning, sagging or for a thumping noise while going over bumps. If so I would have my suspension checked to make sure all the air shocks are working properly.
I've had that issue with my 2009 awd as well... tried to adjust the air suspension, to no luck.
In the end, dealer had to replace height $en$or. Thankfully it was done (last year) under extended warranty.
When I asked ppl here told me it's normal for the front to be higher than the back
