2008 lexus ls460 - complete front end suspension services
Old 11-09-17, 10:39 AM
lvkhang
lvkhang's Avatar
Default 2008 lexus ls460 - complete front end suspension services
My 2008 LEXUS LS460
COMPLETE FRONT END SUSPENSION SERVICES:
8 PIECES UPPER & LOWER CONTROL ARMS COMPONENTS
SHOCK ABSORBERS & FRONT BRAKE!!!
Now its like driving a brand new car
Attached Thumbnails 2008 lexus ls460 - complete front end suspension services-23405707_10211984949593784_5533264826123166091_o.jpg   2008 lexus ls460 - complete front end suspension services-23331162_10211984949473781_1972441239366087042_o.jpg   2008 lexus ls460 - complete front end suspension services-23231302_10211984951153823_1692871256265011489_n.jpg   2008 lexus ls460 - complete front end suspension services-23244398_10211984952753863_2257637925177071231_n.jpg   2008 lexus ls460 - complete front end suspension services-23244566_10211984957073971_5772232392631682167_n.jpg
2008 lexus ls460 - complete front end suspension services-23319262_10211985310802814_7745329171088282218_n.jpg   2008 lexus ls460 - complete front end suspension services-23405992_10211984948633760_1402914720638038716_o.jpg   2008 lexus ls460 - complete front end suspension services-23473094_10211984954593909_1561772436697141489_n.jpg   2008 lexus ls460 - complete front end suspension services-23319208_10211984953473881_4469244861322561368_n.jpg   2008 lexus ls460 - complete front end suspension services-23334187_10211984948793764_1373062774969337575_o.jpg
SevenGuard (09-20-23)
Old 11-09-17, 10:41 AM
UZ214
UZ214's Avatar
Was everything shot? Or this was a preventative measure? How many miles you got on it and how much did you end up spending?
Old 11-09-17, 11:34 AM
fb182
fb182's Avatar
Wow looks like a huge job.
How much did parts cost? What about labor?
Old 11-09-17, 11:43 AM
1WILLY1
1WILLY1's Avatar
what brand of control arms did you go with ?
Old 11-09-17, 12:27 PM
lvkhang
lvkhang's Avatar
mine had 135K miles . the front shock were leaks, and i have some vibration issue with brake too. All the control arms shot
So i send it to my friend shop .
total cost part + labor around $2500
Im very happy with the result .
Old 11-09-17, 06:41 PM
johnnyg66
johnnyg66's Avatar
I did all that plus end-links, tie rod ends and sway bar bushings. I still have a slight knock on the passengers side. I hear it more when turning left at times.
Old 11-10-17, 09:22 AM
Tec80
Tec80's Avatar
Make sure that when they tightened the inner control arm bushing pinch bolts, that the car's weight was on the tires. Otherwise the bushings will be twisted as the car sits normally, and only untwisted when the tire drops into a pothole (which is rare).
Even the Lexus factory in Japan made this mistake on my car. The lower inner bushings are clearly twisted, as evidenced by the spiral crack pattern.
Old 11-10-17, 09:35 AM
Doublebase
Doublebase's Avatar
It really is such an easy front suspension to work on, I bet your friend had no problem whatsoever doing this repair. I like the garage, nice and bright, clean.
I'm don my sway bar bushings, ball joints and links in a couple weeks. I'm really hoping I don't have to remove the steering knuckle to get that ball joint out, but I guess if I have to it's not a huge deal.
Old 06-09-19, 09:16 PM
3GSShoe
3GSShoe's Avatar
Hey Tec,
This is only for the lower control arms right? Where it has to be torqued with the car at ride height? Your photo looks flipped so i wanted to make sure.
Old 06-10-19, 05:35 AM
RussLS460
RussLS460's Avatar
What brand aftermarket parts did you purchase and where? Can you please provide the name of the shop and a phone number? I'm in Southern California.
M3dicDO
10-01-20 02:00 PM
tetoc
05-01-19 06:25 PM
C8V6C
12-02-16 06:26 AM
phsherman
02-20-13 12:16 PM
Jasoneo5
12-17-12 12:33 PM
Quick Reply: 2008 lexus ls460 - complete front end suspension services
