Delaminating Drip Rails?
Old Sep 29, 2017 | 08:37 AM
Raid05's Avatar
Raid05
Both sides are peeling on my 09
Old Sep 29, 2017 | 04:31 PM
RandyV's Avatar
RandyV
Originally Posted by Nospinzone
I'm away on vacation right now and I can't look it up, but I'm pretty sure that those rails just pry right out.
I am going to have address my driver side one when I get back.
OK, appreciate any info when you get back!
Old Oct 4, 2017 | 04:42 PM
RandyV's Avatar
RandyV
Any day now...
Old Oct 6, 2017 | 10:46 PM
RandyV's Avatar
RandyV
Heckuva vacation!
LOL
Old Oct 15, 2017 | 02:48 PM
RandyV's Avatar
RandyV
OK, looks like I'll figure it out on my own.
Old Oct 15, 2017 | 05:07 PM
hfahmy's Avatar
hfahmy
I think many people would very much appreciate some insights on how to take the rails out to paint or change 🤔
Old Oct 17, 2017 | 02:24 PM
Nospinzone's Avatar
Nospinzone
Any day now...
Heckuva vacation!
LOL
Patience grasshopper!
Actually it was a heck of a vacation. We left 9/22 and just got back 10/15. All spent in Italy except 3 days in France. My wife and I are retired.
Unfortunately the thread I had in mind when I wrote my post was this one, and there isn't as much info as I had remembered (did I say I was retired?).
https://www.clublexus.com/forums/ls-4th-gen-2007-2017/793864-drip-rail-removal.html
Maybe
you could PM Lextrician and see if he can provide more info.
BTW, if anyone is going to spend at least 21 days in Europe and needs a car, France has a great program where you lease a car and it is far less expensive than renting a car, and has many advantages over renting. I think maybe I should post a thread about this in a general automotive forum here. I didn't know about it myself until four years ago and since then I've used it every year. It is not well publicized.
Old Oct 23, 2017 | 09:55 AM
RogerN's Avatar
RogerN
Default Rail is covered with a mylar wrap
I had to replace both of mine for about twice the number noted in the thread, and this was with my after warranty maintenance shop! Because they are a mylar-like material, they will have stretched in the wind by the time you try to glue them. Add to that the road grime, oil and wax the rails will have picked up and you will find that gluing them is at best a temporary and imperfect repair. As I recall this is a difficult multi-layer paint job to duplicate so painting the rails could also be a challenge.
Old Oct 23, 2017 | 01:43 PM
Nospinzone's Avatar
Nospinzone
Yes, I can attest gluing is a temporary repair. I think I will try painting with the touch up paint color for my car. There are two sections of about 4" that are bare. Temporarily I'll try painting them and see how it looks/works. It's going to get cold here soon so I'll see how it looks and plan to do something permanent in the spring.
This issue and the peeling on my wheels are my only complaints about the quality of this car.
Old Nov 13, 2017 | 07:25 PM
Crowbar64's Avatar
Crowbar64
Default 2008 LS drip rails delaminating
I just pulled the plastic color matched laminate off mine today,
the stainless look is not bad.It came right off in a couple pieces
no glue residue.
Old Jan 6, 2018 | 02:19 PM
RandyV's Avatar
RandyV
I decided to strip the delaminating film off the rails. Using a heat gun on low and working slowly, the stuff pulledd off. There was some glue residue in some areas rthat came off with a bit of work using alcohol, so as not to damage the surrounding paint.
The chrome looks like it is supposed to be there as it accentuates the matching chrome around the windows and doors.
Before and after:
Old Jan 6, 2018 | 04:22 PM
Spudo769's Avatar
Spudo769
That actually looks pretty good Randy V.
Old Jan 6, 2018 | 07:53 PM
Nospinzone's Avatar
Nospinzone
I agree, that does look good. I didn't do anything with mine this fall. I was going to try to paint them with touch up paint, but I didn't get to it and it's freezing here now. I may just do what you did.
As an aside, there is a product called Goo Gone. It is as effective as alcohol and doesn't damage the surface like alcohol sometimes does.
Old Jan 6, 2018 | 08:45 PM
RandyV's Avatar
RandyV
GooGone is a bit more aggressive on paint than IPA, from what I understand. Maybe not.
IPA has no deleterious effects on modern clear coats - when used sparingly, within reason.
Old Mar 25, 2018 | 07:19 AM
DavidinCT's Avatar
DavidinCT
Might have to pull them all off, I ran into this issue on BOTH sides in the front....WTF...
I'll also check some auto repair places for a estimate, if it's around $100-150 I might just do it
