Dead factory battery replaced with Costco Battery Interstate/#27 Ls460
#31
A8 long wheel base. Mine is the 2nd largest in the A8's. Was not worth spending an extra $100 for a bit more reserve on the biggest... lolThe big batteries are mainly for the auto stop start system I believe. Lots of reserve to power the systems with the engine off.
#32
I would not pay for labor. The LS does not have a charging management system so nothing needs to be reset. I paid $230 for my battery and installed myself. Most good AGM's go for about $200 - $250 for the battery. For lead acid I would not spend more then $120.
As far as size, often the OEM will vary in size based on options for the car. Quick search also came up with BCI group 27.
#33
If an AGM costs twice as much as a regular battery, does it last twice as long? If not, then wouldn't it be more cost effective to buy two regular batteries over time? Just curious because I do not have experience with AGM batteries. Wish I could have found a Panasonic to go back in under the hood. I went with a Duralast Gold because I saw good experiences posted on the forum (and because Costco didn't stock my size at any of the three local locations). It has a 5 year warranty (3 year free replacement) for $120.
I always replace batteries when they get into the 4-5 year age because I don't need a dead battery and end up stranded..... Cheap insurance on a job that is easy to DIY.
#34
The extra reserve is what applies to my situation vs longevity. They do not last twice as long but they do tend to last longer.
There are a few distinct advantages of an absorbed glass-mat battery versus a lead-acid battery:
- An AGM battery has a lower internal resistance than a flooded lead-acid battery, which allows faster recharge.
- The AGM battery doesn't produce nor expel hydrogen/oxygen gasses like the flooded lead-acid battery. Therefore, it doesn't have any electrolyte or water loss.
- When comparing the same group size battery, AGM batteries allow additional plate surface area. More plate surface area = high ratings in cold cranking amps (CCA) and/or reserve capacity (RC).
- AGM batteries do not exhibit terminal corrosion. No corrosion means less battery maintenance.
#35
Thank you, Lexuslsguy. That is interesting to know. Is it still common to have to add water to batteries? I don't think I've ever added water to a car battery ever since I began driving 22 years ago and honestly I never checked. Maybe I should have but by the time each battery needed replacing it was already 4+ years old and doubtful if some water would have made a difference.
#36
#37
About a year ago, we had a spirited discussion on battery replacement. For those of you who have a keen interest in this subject, that thread might be interesting reading.
https://www.clublexus.com/forums/ls-...w-battery.html
FatherTo1 (07-26-17)
FrankReynoldsCPA
01-05-13 12:54 PM
