Passenger seat heater/cool making clicking noise
My passenger side seat has been making a weird clicking sound. I finally narrowed it down to the heating cooling. It makes the sound like when you turn on the heating switch. Also, when I actually turn on, everytime the clicking goes on and off, the light for the heating/cooling goes on and off, indicating that it's not working. I took to dealer and they said it will cost $1300 to replace some unit under the seat. That is just too much for something I use a couple times/month. Also, I just had the car in for a fuel pump failure, and that cost $1900 already. This LS460 is much more prone to problems than my LS 430 and LS400 combined. Is there any way I can disable this heating/cooling so it stops making the clicking noise. The noise is quite loud; enough that my children in the back seat would ask "what is that annoying sound?" Thanks, everyone.
It sounds like a relay....but it is actually an "on and off" sound. I will pick up the car tomorrow and hopefully will know more about what they diagnosed. Thank you, Jmcraney for your suggestion. I did put it in neutral (off position), the clicking noise still comes on and off regardless. I will update you what the specific part the dealer quote.
Ok, I received my car back and the dealers said it was the seat heating/cooling ecu that is faulty. It has a loose connection and would be $1300 to replace. They were able to disconnect it, so now there is no more clicking, but no more heating and cooling on that seat. I think I can live with that.
JackTheCat
05-21-19 07:16 PM
