Low Compression & Oil Consumption
Old Mar 22, 2017 | 12:04 PM
  #31
greekguy66's Avatar
greekguy66
Yes. We do have a Loaner Car and always have had one each time we left the LS for some work.
Our local Lexus Dealer has always been upfront, honest and very good customer service & support.
Old Mar 22, 2017 | 12:32 PM
  #32
Kennyr44's Avatar
Kennyr44
Awesome, this is why manufacturer extended warranty's are the only way to go.
Old Mar 22, 2017 | 01:31 PM
  #33
greekguy66's Avatar
greekguy66
I think sometimes that depends also on the manufacturer.
I know from experience BMW will not warranty anything once the warranty expires. A few friends had Lexus Extra Care still take care of them even though their cars were 5k miles out of warranty.
Old Apr 10, 2025 | 06:08 PM
  #34
GS350Canada's Avatar
GS350Canada
Originally Posted by mckellyb
So, the dealer's claim is it went through 5 quarts of oil in 4K miles.
Skepticizm...I haz sum.
I mean, I cannot imagine a Lexus dealer not putting 9 quarts plus a little back into the engine, but strange things happen.
Standard compression pressure: 1400 kPa (14.2 kgf/cm2, 203 psi) or more
Minimum pressure: 980 kPa (9.9 kgf/cm2, 142 psi)
They should have done both a 'dry', which is what it sounds like they did, and a 'wet' compression test. The 'wet' one adds a little oil into the cylinder before doing it, so as to determine if the reason is worn rings or cylinder damage. Being as you reference a leak-down test, you probably know this, but I just wanted to throw it out there.
All of them are low, which I can't believe you couldn't feel as a lack of power, but if the car is driven gently, it may go unnoticed.
Let me put a few brain cells on it, because this is a tough call.
edit: How much oil does this engine consume between changes, historically? How often between said changes, under your ownership? How long/how many miles since you bought it?
Sorry to bump an old thread, but I haven't found compression specs for the 1UR-FSE anywhere else. I'm looking at a GS460 to buy, but want to get a compression test done first - I'm guessing the numbers should be the same as the LS460 numbers you gave?
EGLIDE
RC F (2015-present)
30
Nov 7, 2016 06:07 AM
NobleSpine
Mar 2, 2015 12:42 PM
chris6878
IS F (2008-2014)
24
Jun 21, 2011 04:16 PM
pavelekPL
Jun 3, 2011 08:35 PM
lexus-is2
Apr 26, 2011 06:25 AM
