I'm back!
Finally introducing myself on the 4LS forum.
Got back into an LS finally after my '02 was hit while it was parked about a year ago.
Loved that car. Ecru interior and Blue Onyx Pearl exterior with all options air springs and rear AC.
Sad RIP Story here
Had a '94 1LS before that in silver.
In between I grabbed an '07 GS Ultra AWD to keep myself out of unscheduled debt (I replace every 5 years) and because the market for 4LS here in Toronto was only white, silver or really roughed up.
The 3GS is a bucket IMO. That's all I can bear to think about it.
Great engine except it burns oil, great body but the Obsidian paint is so soft and...
So. NOISY. Rattles like a ****. Coming from a dead silent LS previously, it was honestly unbearable.
Finally was able to get my hand on an '07 Black Saphaire pearl SWB with 120,000km (75,000 miles) optioned up with everything but air springs and rear AC. Perfect match except the Ecru semi aniline leather which I REALLY miss.
Even got the door closers on a SWB. I didn't want an L. Not sure why.
Called the guy 45 mins after he posted it. Took it home after I gave them a weekend to clean.
Needed the rotors turned to kill a vibration on hard braking: still considering installing some ceramics to ease the grabbiness.
There's a definite click coming from the actuator as well, so I may hit up a dealer soon to see about getting the warranty extension swap done.
First things I got done (just to get her back to where my 430 was):
LEDs everywhere (still working on Nike lights as my LEDs seem to overheat and flicker only when the lights run a while).
Vais BT and motion defeat installed. Had GROM USB + BT in the 430.
Full detailing and NVH hunt. Squeaks, clicks, rattles and knocks eliminated (mostly). More later...
Completed my droopy glovebox repair a couple days ago.
Added some velcro padding to the dash against the glass to stop a clicky kinda squeak from there.
Silicone lube in all of the window channels helped the dreaded wind noise A LOT. I do need to bump down the driver side to seal it properly so I'll see what I figure out for that. Considering maybe a narrow felt strip in the channel along the top...
Took out the console and polished out the previous owner's scratch work. Some 2000, then 3000 sandpaper, then the random-orbit for a bit.
Control arms will come eventually I suppose: left-front-upper-forward arm is a little jiggly by hand: haven't had a chance to look at the bushings with a light yet.
Already enjoying being back in the flagship.
Sad RIP Story here
Well done and welcome back!
A few weeks ago, I replaced my rotors with Centric Premiums and my pads with Centric Posi-Quiet ceramic pads. The difference is NIGHT and DAY! SW15 (Steve) did the same and reported similar observations. The "grab" is COMPLETELY gone. I also did my control arms, but that's a whole different story, but equally happy with that as well. Cost inc labor for the CA's was about 1500 dollars which also included new shocks. I did the brakes myself and got the parts from RockAuto.
Looking forward to your input here at CL.
Needed the rotors turned to kill a vibration on hard breaking: still considering installing some ceramics to ease the grabbiness.
Hi and welcome back.
Very nice job in the center console. Looks brand new.
Sounds like you can do a lot of things for yourself and I know what an accomplishment that can be.
Good luck on the small things and hope you have many miles of enjoyment from the 460. I love mine.
Cubby
Cubby
Better than the GROM because it does display the info. The GROM didn't do info on screen on either my 430 or the GS.
Love it!
I was letting the brakes cut a bit, but I think I'm going to go ahead and get the fronts turned and throw in the ceramics I ordered.
Braking is smooth now but I'm used to that smoother feel of ceramics from my 430 and the GS, regardless of the noisier brake action during warmup.
My extra padding along the dash isn't enough to silence that clicky dash rattle I have on hard bumps.
Presently I keep the case from my little combination tool forced between the space.
Its about 1/8th inch thick flattened out and this silences it completely, no matter the bump!
Gonna look for some kind of rubber or felt blocks (imaginating something like the little rubber feet that come with some electronics) and insert a few, maybe 3 along the glass to maintain that space.
LS600HL shift **** next...
Amazon, not OEM.
Are you sure you want to turn the rotors? Seems like a waste of time to me. When you turn them, they're gonna be thinner and will just warp that much sooner again. Your call obviously, but I'd think this one through. Factory Lexus rotors are notorious for warping.
My extra padding along the dash isn't enough to silence that clicky dash rattle I have on hard bumps. Presently I keep the case from my little combination tool forced between the space. Its about 1/8th inch thick flattened out and this silences it completely, no matter the bump! Gonna look for some kind of rubber or felt blocks (imaginating something like the little rubber feet that come with some electronics) and insert a few, maybe 3 along the glass to maintain that space.
Just a quick update.
I've now completed a few more items on my to-do list.
Also already bought 4 aftermarket upper control arms. Install soon.
I love it when a car gets better and better in the months after you buy it...
- New deep pile grey mats installed. So deep and fluffy.
- 600h shift **** installed.
- Triangle trim and bump down wind noise fixed. So quiet inside.
- All three air filters replaced.
- Headlights aimed up just a bit.
- LED nike lights changed to ones that can handle the heat. No flickering, bright, and the colour matches the CBI HID nicely.
- Accessory drive belt replaced. (had a tiny squealing starting)
- Ceramic brake pads installed.
