Any Tricks to Access Front Differential Fill Bolt?
Old 09-14-16, 04:46 AM
alain173
alain173's Avatar
Default Any Tricks to Access Front Differential Fill Bolt?
Spent several hours yesterday trying to access front diff fill bolt. Had to remove skid plates and a crossmember, but the fill bolt is wedged up between steering rack and shaft, and my 10mm allen just couldn't access it. Anyone with experience can share some advice? Maybe remove front drivers tire and go from there? looks like i might need some special angled allen wrench or something??? Car is 09 LS460 AWD, thanks
Old 09-14-16, 07:49 PM
roadfrog
roadfrog's Avatar
I answered in your other post.
Old 09-16-16, 07:19 AM
superdenso
superdenso's Avatar
If this doesn't help you maybe you can post a pic:
Are you going for the part numbered 41181D?
http://www.lexussouthatlantaparts.co...ey_model=15671
Old 09-16-16, 08:36 AM
alain173
alain173's Avatar
Thanks for the replies. Maybe i need to rephrase my question. I know where the fill plug is, and i know its a 10mm allen, the problem is how to access it? its virtually impossible to get at it as is without dropping steering rack or some special tool? I was hoping someone has done this before and can shed some light. I called the dealer yesterday and they said it was a difficult job because their techs need to drop subframe to get to fill plug? Not sure if thats the case but I'm certain there is an easier path.
Old 09-16-16, 07:14 PM
caha14
caha14's Avatar
Personally, I would sign up on techinfo.toyota.com to see what the "official" procedure is. Sometimes there is still an "easier" way (example: low beam bulb replacement can be done more easily than what the service manual says), but it should help regardless. A 2-day subscription used to be $15, and you can search for any procedure of interest, so it's worth it, IMHO; I've subscribed many times over the years.
Behemoth7
04-05-17 04:43 AM
gabzor
05-26-15 06:06 AM
dal_lexus
GS - 1st Gen (1993-1997)
12-10-13 08:08 AM
nicks88
11-23-12 01:03 PM
whooper20
Performance & Maintenance
08-21-11 09:31 AM
Quick Reply: Any Tricks to Access Front Differential Fill Bolt?
