Confused about check engine light
Old 03-21-21, 08:02 PM
RolloC
RolloC's Avatar
Fault Code P0012 "The fault is internal in the engine camshaft gear & motor relating to internal engine timing. Front timing case needs to be removed & the timing chains removed from the engine to be able to replace the camshaft & motor (2 different parts)". That's the quote detail.
Nearly all trouble codes appeared from the cars computer the first time so they cleared them as they couldn't determine what was wrong. 4 hours later only the PCS warning light appeared & then the computer retrieved 1 fault code P0012.
brandon17
Maintenance
07-03-18 02:15 AM
jhp9mm
27
02-28-14 01:27 PM
nbeihl
04-06-11 09:18 AM
orangeteg
02-09-10 12:14 PM
xsuperjoex
04-07-06 09:17 PM
Quick Reply: Confused about check engine light
