2009 Lexus Ls460 @brake issues@
Old Dec 24, 2015 | 07:00 AM
lcyoung23's Avatar
lcyoung23
Default 2009 Lexus Ls460 @brake issues@
hey, i just bought a lexus ls460 and the brake are hard. after driving around for a while like a dummy the brakes going to the floor. I took it to the dealership and they told me the brake pump anti-lock actuator. have anybody had this problem with the brake system
Old Dec 24, 2015 | 08:25 AM
Doublebase's Avatar
Doublebase
The brake actuator failure is a know problem with here cars and if it's at the dealer you can expect to pay $3,000 for the repair...maybe more.you can buy used actuators for around $700 and have someone else install it, but it sounds like it's a little late for that.
Old Dec 24, 2015 | 09:29 AM
lcyoung23's Avatar
lcyoung23
I actually found it on eBay for $700 just got it installed works perfectly have to reprogram it
Old Dec 24, 2015 | 10:23 AM
Doublebase's Avatar
Doublebase
Awesome! Dealer reprogram it, or independent?
Old Dec 24, 2015 | 03:22 PM
sdwtchlvr's Avatar
sdwtchlvr
Wow, nice work. Am I missing something or did you find it on eBay and have it installed within 2.5 hours of your first post?
Old Dec 25, 2015 | 01:36 PM
is150's Avatar
is150
Lol. I was thinking the same thing
Old Jul 26, 2024 | 09:02 PM
Ottomobille's Avatar
Ottomobille
1st Gear
can anybody give me some clarification about exactly what part is failing? I believe my LS is showing symptoms of this problem. There is a business locally that sells these abs modules. Is it the abs module itself? or the piece mounted beside it with the black cylinder? i assumed this was the pump motor.
These abs models have several part numbers, does it matter which one I buy? do these modules need to be programmed at all or are they plug and play? I am a mechanic with quite a bit of experience but an unfamiliar with these brake systems.
I wish it had a normal brake booster lol.
boz151
May 19, 2023 10:51 AM
cycle22
May 20, 2019 10:24 PM
UZ214
Nov 12, 2017 09:49 AM
gtunic
Great Lakes
Oct 9, 2017 02:07 PM
LSRIDER
Jan 16, 2011 07:13 AM
