Heated Steering Wheel Adjustment?
Old Nov 22, 2015 | 09:57 PM
jimrd's Avatar
jimrd
Default Heated Steering Wheel Adjustment?
2015 LS460, just starting to get some cooler weather and the heated steering wheel has fired up a couple of times. Only problem is that I'm not cold! How does the heater decide to turn on and are there any adjustments? Thanks in advance!
Old Nov 23, 2015 | 02:14 AM
Bart1958's Avatar
Bart1958
My 2007 LS 460 has a button to switch the heating for the steering wheel on and off. I suppose yours has one too !!
Old Nov 23, 2015 | 05:31 AM
jimrd's Avatar
jimrd
Bart,, yes there is the on/off switch...but I was looking for some sort of "turn on" adjustment like an outside temperature setting or inside/outside temp differential, etc....
Old Nov 23, 2015 | 05:47 AM
jmcraney's Avatar
jmcraney
Refer to your Owner's Manual for your 2015 LS460 under "Customizable Features."
You have the option to heat the steering wheel automatically or manually and there are 5 options for selecting the automatic heating time.
The options are described on pages 389 and 572.
http://drivers.lexus.com/t3Portal/do...f/OM50E06U.pdf
Old Nov 23, 2015 | 10:20 PM
jimrd's Avatar
jimrd
Thanks jm...I had found that info. I was hoping there was some setting to change the temperature threshold...guess there isn't one..thanks..
Old Nov 28, 2015 | 05:00 AM
Chaos236's Avatar
Chaos236
Great post thanks. Almost have to keep the owners manual in the bathroom library to stay up on it.
Old Mar 21, 2020 | 06:05 PM
R Z's Avatar
R Z
This was driving me crazy. I finally found the settings and turned the heated steering wheel option off!! So glad!!!!
pavelmyn
Nov 29, 2016 07:00 AM
kenborch
Nov 28, 2016 12:25 PM
Trek
Oct 23, 2013 04:45 PM
Big Jimm
May 7, 2006 11:48 PM
