Steering Wheel Removal
Old Mar 5, 2015 | 07:17 AM
zxfiles007's Avatar
zxfiles007
Default Steering Wheel Removal
Does anyone have instructions on how to remove the airbag on the LS460/600?
Old Mar 5, 2015 | 09:49 AM
lieup's Avatar
lieup
Default How to remove LS460/600 steering wheel air bag
This DIY is ONLY for removing steering wheel air bag NOT steering wheel.
Good luck!
Warning::::::::: Make sure you disconnect the battery before you do this.
Attached Thumbnails Steering Wheel Removal-step1.jpg   Steering Wheel Removal-step2.jpg   Steering Wheel Removal-img_4827-copy.png   Steering Wheel Removal-img_4829-copy.jpg   Steering Wheel Removal-img_4815-1-copy.jpg
Old Mar 5, 2015 | 09:52 AM
lieup's Avatar
lieup
Default Air bag
Air bag back view, after completely removed.
Old Apr 21, 2015 | 09:39 PM
zxfiles007's Avatar
zxfiles007
Awesome. Thanks
Old Apr 22, 2015 | 09:47 AM
roadfrog's Avatar
roadfrog
REMOVE COWL TOP VENTILATOR LOUVER RH See: Starting and Charging\Charging System\Alternator\Service and Repair\Removal
DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL CAUTION: Wait at least 90 seconds after disconnecting the cable from the negative (-) battery terminal to prevent airbag and seat belt pretensioner activation.
NOTE: After the engine switch is turned off, the HDD navigation system requires approximately 6 minutes to record various types of memory and settings. As a result, after turning the engine switch off, wait 6 minutes or more before disconnecting the cable from the negative (-) battery terminal.
REMOVE SWITCH AND VOLUME CASE
(a) Using a screwdriver, remove the switch and volume case.
HINT: Tape the screwdriver tip before use.
REMOVE NO. 2 STEERING WHEEL COVER LOWER
(a) Using a screwdriver, remove the No. 2 steering wheel cover.
REMOVE STEERING PAD ASSEMBLY
(a) Using a T30 "TORX" socket wrench, loosen the 2 "TORX" screws until the groove along the screw circumference catches on the screw case.
(b) Pull out the steering pad from the steering wheel assembly and support the steering pad with one hand as shown in the illustration.
NOTE: When removing the steering pad, do not pull the airbag wire harness.
(c) Disconnect the horn connector.
(d) Disconnect the 2 connectors and remove the steering pad.
NOTE: When handling the airbag connector, take care not to damage the airbag wire harness.
REMOVE STEERING WHEEL ASSEMBLY
(a) Remove the steering wheel set nut.
(b) Put matchmarks on the steering wheel and main shaft.
(c) Using SST, remove the steering wheel assembly.
SST: 09950-50013
09951-05010
09952-05010
09953-05020
09954-05011
REMOVE STEERING SHAKE DAMPER
(a) Remove the 2 screws and shake damper.
REMOVE STEERING PAD SWITCH ASSEMBLY WITH MODULATOR
(a) Disconnect the 2 connectors and remove the 4 screws and steering pad switch.
REMOVE CRUISE CONTROL MAIN SWITCH ASSEMBLY
(a) Disconnect the connector and remove the 2 screws and cruise control main switch.
REMOVE STEERING WHEEL HEATER CONTROLLER
(a) Disconnect the 2 connectors and remove the 2 screws and heater control.
Old May 2, 2021 | 01:39 AM
jdanielca's Avatar
jdanielca
Do I really need a service tool to remove the steering wheel? If not then other than the T30 screws on the side what size and type bit do I need for the centre bolt?
Batmobile
Oct 27, 2022 01:57 PM
stew1399
Sep 5, 2018 02:18 PM
MrBruin09
Feb 28, 2014 09:28 AM
fbrown159
May 25, 2013 06:14 AM
angmedic91
Nov 1, 2009 08:34 AM
