Cleaning Alcantara Headliner
Old Sep 18, 2014 | 07:05 PM
DJWLDW's Avatar
DJWLDW
Default Cleaning Alcantara Headliner
I did 2 searches but could not find the answer. I have the Semi-aniline leather-trimmed interior with Alcantara Headliner and now have 2 fingerprints above the passenger door from reaching in with soiled fingers. What is the best method or cleaning agent I should use to clean my Headliner?
Dennis
Old Sep 18, 2014 | 07:12 PM
satiger's Avatar
satiger
Did you try with mild soap water mix?.
Old Sep 18, 2014 | 09:03 PM
williakz's Avatar
williakz
Hope this helps:
Alcantara Maintenance.pdf
Old Sep 19, 2014 | 02:12 AM
slimjimtel's Avatar
slimjimtel
Alcantara is a fancy name for a polyester microfiber. Much like the microfiber fabrics you can purchase on furniture these days, However the alcantara has a higher pile to it. With it being a spun polyester, it is very easily cleaned with a damp rag with a very mild soap. Dawn dish soap is a good cleaner, it will help if it is an oily finger print.
Old Sep 19, 2014 | 04:15 AM
DJWLDW's Avatar
DJWLDW
Thanks Guys will give it a try this morning
Dennis
Old Sep 19, 2014 | 07:35 AM
dlbuckls10's Avatar
dlbuckls10
Very useful info.
Old Sep 19, 2014 | 08:39 AM
retlex's Avatar
retlex
Smile
When cleaning these headliners you have to move your hand with the grain, otherwise it won't appear smooth and looking natural with all the same texture. I had the same problem with hand prints on mine. Valley Lexus in Modesto said their detail guy uses denatured alcohol. They said the problem is with other cleaning products, they can leave residue, leaving unmatch materials. I have the semi-aniline leather with alcantara headliner. I saw some other areas that appeared soiled so I bought some at lowes. I used it with with a white paper towel and it's perfect. I poured a light amount on towel because I was skeptical. The paper towel allows you to rub lightly. It removes the soiled spot then evaporates. The key is moving one direction only in the direction of the grain. The headliner looks flawless as it did, my 2 cents
Old Sep 19, 2014 | 04:41 PM
DJWLDW's Avatar
DJWLDW
used the damp cloth and Dawn and it took it right off. You do not know it was even there. Thank You for the tip
Dennis
Old Sep 20, 2014 | 09:30 AM
jayclapp's Avatar
jayclapp
You need to be very, very careful if using denatured alcohol. I was doing that and accidentally dropped a single drop on the transmission panel. It almost instantly took the finish off, and left an ugly near white spot. A horrible spot to have a problem. Every time you get in the car or look near the console it stares you in the face.
Immediately ordered a replacement part and installed it myself.
My suggestion, don't let denatured alcohol anywhere near the interior of your car!
Old Sep 21, 2014 | 11:47 AM
LS2k's Avatar
LS2k
Been using Mr clean magic eraser with great success.
jacobjohn
Automotive Care & Detailing
Jun 30, 2013 06:45 PM
meis250
17
Sep 19, 2012 06:14 AM
TYPEONE8
13
May 28, 2011 10:31 AM
405
May 12, 2010 08:44 PM
tarnut77
Feb 6, 2008 12:28 PM
