ELM327 OBD2 - Which android app do you like?
Old Nov 6, 2021 | 05:05 PM
V8cars's Avatar
V8cars
10th Gear
With Carista dongle and app, you can also register new TPMS sensors on LS460. I was not able to register them with Techstream, but Carista worked really well.
Old Nov 6, 2021 | 07:13 PM
ill57's Avatar
ill57
9th Gear
I'm looking for an app to see which tpms sensor is bad.. any suggestions?
Old Nov 6, 2021 | 07:36 PM
swfla's Avatar
swfla
Because tires get rotated, an app won't tell you which one even though each one has a unique identifier number.
Old Nov 6, 2021 | 07:38 PM
V8cars's Avatar
V8cars
10th Gear
I do not think an app can do that for 2007-2012 LS. You would need to lower the pressure one tire at the time and check which one does not respond. Or get a TPMS scanner like Autel TS401.
Old Nov 6, 2021 | 07:42 PM
ill57's Avatar
ill57
9th Gear
Tpms light is on and the psi values are no longer displayed. Trying to find an app where I can get access to psi from the other 3 tires then I can find the culprit.
Old Nov 6, 2021 | 07:58 PM
V8cars's Avatar
V8cars
10th Gear
You can clear the TPMS warning with either Techstream or Carista (with the Carista dongle). Battery disconnect might works as well. Then use either of these tools, or just the car menu, to play with the tire pressures and identify the bad sensor.
Old Nov 6, 2021 | 08:03 PM
ill57's Avatar
ill57
9th Gear
Thanks, I'll give it a try and report back.
Old Nov 7, 2021 | 03:28 PM
coolrydz's Avatar
coolrydz
Originally Posted by scorpio74
I have Carista app and I like it. I'm able to turn off the DRL through the Carista app and there are many other features as well that I didn't want to change the setting LPS. I also have Torque pro as well.
Has anyone ever tried Carista app on 2IS?
I have noticed it doesn't support 2IS.
Old Nov 7, 2021 | 03:50 PM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
You should ask that in the 2IS forum, this is the 4LS area.
Old Nov 8, 2021 | 06:16 AM
DJWLDW's Avatar
DJWLDW
Where is the 2.1 upgrade at? I could not find it in the Apple app store.
Dennis
Old Dec 21, 2023 | 11:33 AM
EEng's Avatar
EEng
I am looking at the Carista OBD adapter (Not EVO). Will I be able to view the codes from the different ECUs with this adapter? What about ELM?
RLM
RX - 3rd Gen (2010-2015)
Mar 9, 2016 09:35 AM
BrandonYas
Mar 18, 2014 06:58 PM
xmike714x
Jun 4, 2011 11:56 PM
