Trying to remove Data Controller, going back to stock
Old Dec 13, 2012 | 11:02 PM
phenomeno's Avatar
phenomeno
Default Trying to remove Data Controller, going back to stock
I have an 07 LS 460L with R-Spec data controller installed. I want to remove the data controller and go back to stock. I removed the data controller and the rear stays super low and tucked and the front stays raised like 3 fingers above the tire. So i reinstalled the data controller for now. I was wondering is there a way to reset the stock ride height after removing the data controller? Any help please. Thanks everyone.
Old Dec 14, 2012 | 09:48 AM
CJITTY's Avatar
CJITTY
When you took out the controller, what setting was it on. I have always wondered about this. If it was me, I would put the controller on normal select mode..then let the car settle back to normal height. Then remove the controller. I would try putting the car to height high mode..drive around for a while then turn off height high..let it settle back in and.see if that worlks. We posted that in the Air Suspension thread and it worked for a couple folks that still had the controller.
Old Dec 14, 2012 | 07:12 PM
RandyV's Avatar
RandyV
Why want to remove the controller?
Old Dec 22, 2012 | 06:53 AM
phenomeno's Avatar
phenomeno
Thanks Cjitty, ill try it. Should I try normal select up arrow or normal select down arrow? The first time I removed it I didn't do the normal select mode and just pulled the controller out with whatever setting it was on. Ill try it afyer the holidays.
Old Dec 24, 2012 | 06:41 AM
CJITTY's Avatar
CJITTY
Let's say you are at memory 2 position. .. just use up arrow until it displays "normal select" and leave it alone. I never notice the up and down arrows on normal select but when I put the display in height level mode to get the bar graph display, I will look at the display while going over 60mph and bars begin to extend to the sides indicating the car is lowering itself as normal when at highway speeds.
rduncan239
May 4, 2024 12:42 AM
wsantiago
Performance
Jun 10, 2016 04:18 PM
FreddyG
Oct 2, 2014 09:10 AM
pRaHjeC
17
Feb 18, 2007 09:35 PM
nosyajg
Jul 11, 2006 05:02 AM
