Front Screen Of LS460 DVD Capable?
Old Jan 17, 2012 | 02:29 PM
rominl's Avatar
rominl
exclusive matchup
Originally Posted by adamls2
So would it be a god idea to install both the Nav override and ML+ module at the same time? I need to go look at the install thread for them but I think I will have a professional do it most likely
i will most definitely recommend that. you are taking out the exact same components already, might as well install both together
Old Jan 17, 2012 | 03:12 PM
InRBigness's Avatar
InRBigness
what does the ML+ module get you that the Prestigious Society nav over ride doesnt provide? I seem to be missing somthing.
Okay never mind. I see that this will add ipod connectivity to the nav system. I dont need this as I have AUX and USB ports in my RX.
Please return to your regularly scheduled lurking of the forums. Nothing to see here, move on.
Old Jan 17, 2012 | 03:36 PM
Shibumi1's Avatar
Shibumi1
So would it be a good idea to install both the Nav override and ML+ module at the same time? I need to go look at the install thread for them but I think I will have a professional do it most likely
i did both an im pleased with the results... i almost exclusively listen to my ipod now... an on roadtrips the 150+ movies on it make long drives a lil easier.. and not having to stop to enter an address is the best.....
Old Jan 17, 2012 | 05:47 PM
PeachyKeen's Avatar
PeachyKeen
Any of you guys used a product like the Seagate GoFlex with your iPhone / iPod touch, etc in your car and through the system?
I've thought about picking one up lately. It's a 500GB hard drive that has wireless and iOS apps to access it and it really opens up the options of having lots of music / movies stored on it to use.
Old Jan 17, 2012 | 07:00 PM
Franco240's Avatar
Franco240
Where do you purchase the ML+ module?
Old Jan 17, 2012 | 07:37 PM
Dema's Avatar
Dema
Does anybody know if there is some firmware fix to show national characters for song names when you play ipod. So far I like ipod interface but not showing national charcters just dots ruines the deal.
Old Jan 17, 2012 | 08:10 PM
kitchamp's Avatar
kitchamp
Purchase directly from Vaistech, http://www.vaistech.com/dev/mlp.php
Old Jan 17, 2012 | 11:04 PM
rominl's Avatar
rominl
exclusive matchup
it's not a problem of the vaistech units, it's a problem of the lexus navigation system. it doesn't use unicode. sux
at least with ml+ it will display whatever you see on the ipod itself
Old Jan 18, 2012 | 02:00 PM
adamls2's Avatar
adamls2
That sounds great!! Unfortunately I have the premium sound system and I was told that the backup camera issue is still present with my car. They said they would notify me once the problem is fixed and fully compatible with my car. BTW thanks Henry for the help
Old Jan 18, 2012 | 03:29 PM
305Busa's Avatar
305Busa
Ok, I scrolled thru this thread and I cant seem to figure something out. I have an 07 with the ML and my rear camera wont work sometimes. I see something on here about that but couldnt figure out what I needed. Can somone lead me in the right direction? Ive taken it to the dealer but since it only happens sometimes, they cant seem to get it "not to work" when its there.
Old Jan 18, 2012 | 07:48 PM
kitchamp's Avatar
kitchamp
Hi Busa-
The camera issue we are referring to in this thread used to occur following the installation of the Vaistech MediaLinq Plus (ML+) iPod integration module. I wasn't sure if this is what you are referring to, or whether you mean that you have the Mark Levinson sound in your LS (I know, the "ML" acronym does need some clarification).
If you do have the Vaistech unit and are experiencing camera issues, contact Vaistech. I did extensive testing/troubleshooting with them, and they were able to correct it with a software update that is now included on newly purchased units.
If you do not have the Vaistech, then the camera issue you are experiencing is different from the one mentioned in this thread and involves the stock Lexus components, not the Vaistech unit.
I hope that helps!
Old Jan 18, 2012 | 08:19 PM
305Busa's Avatar
305Busa
Thanks for clarifying. The issue I'm having is totally different.
Originally Posted by kitchamp
Hi Busa-
I hope that helps!
jasone36
Mar 21, 2017 04:45 PM
BBQBOY
May 27, 2014 09:54 AM
sidwin
GX - 1st Gen (2003-2009)
Feb 6, 2012 10:42 AM
jaytone
Sep 6, 2009 08:23 PM
frebay
May 2, 2006 11:19 PM
