Lighter
Old Jan 17, 2012 | 05:51 PM
wrisperj's Avatar
wrisperj
Default Lighter
Anyone have any issues with their cig lighter. Mine stopped working. I checked all of the fuses in the trunk and none are popped. The aux in the arm rest and back seat works fine. Do I need to replace the lighter. It's an 08 460.
Old Jan 18, 2012 | 03:25 PM
Nospinzone's Avatar
Nospinzone
So is it the actual cigarette lighter (the piece that gets really hot) that is not functioning? If so, I think the size is universal so you could borrow someone else's and see if it works in your car.
One other thought, there are several fuse boxes in the car in case you didn't check them all.
Old Jan 19, 2012 | 04:58 PM
wrisperj's Avatar
wrisperj
It's not the lighter itself. It's the socket if u will. I was using a portable air compressor to put air into my daughters basket ball I checked the fuse box in te trunk. I guess I have to search for the rest and check them. Thanks.
Old Jan 19, 2012 | 06:39 PM
Nospinzone's Avatar
Nospinzone
Yea, check your manual for the locations of all the fuses. If you don't have a manual, let me know and I can look them up for you.
Actually, just log in to Lexus and you can view the manual online.
Old Jan 19, 2012 | 11:24 PM
jgbackes's Avatar
jgbackes
I'm assuming you plugged it into another socket to prove it was not the compressor itself.
There are five different junction boxes (fuse boxes) in your car. The trunk, passenger side, driver's side, and two under the hood. Each location has a legend for what fuses cover what circuits.
Looking on www.alldatadiy.com It shows that there is a 15 amp P-CIG fuse located in the "Passenger Side J/B Inner Circuit". I have a 2012 so it might be different on your car.
Good luck, you'll find the fuse.
Last edited by jgbackes; Jan 19, 2012 at 11:42 PM. Reason: Added pictures of the location of the Passenger J/B
barncat
May 7, 2012 06:51 PM
SCXray
Jan 12, 2012 06:04 AM
haysooom
Aug 11, 2011 09:20 AM
Batmobile
Jan 10, 2008 01:56 PM
venomous
Jan 8, 2006 06:55 AM
