Same thing happened to me. Dealer folks couldn't figure it out. Said take to body shop. Made appointment for them to removed seats and try to fix. That night managed to work out the item that was jammed, but trunk would only open 1/8 inch with metal key. Read about fix in another forum and it worked. Disconnnected the positive side of battery, waited 30 secs. Problem solved. At first it would only open with metal key, but I discovered the Valet Lock Out in glove compartment had set itself to "On." Unset this and everything worked fine.
What does "stuck open" mean? Are you saying that the retractor will not pull it completely closed? Or, are you saying the lift struts are holding it up? Or are you saying that something else is preventing you from pushing it closed?
