i just switched to winter tires and have tpms light on as well as system melfunction triangle .searched how to reset but manuel speaks of a reset button right hand lower dash under park break .i do not have the button .please shed some light how i can reset tpms ls460l 2007
thankyou
Dear Vancouverl,
first all tires should be 33psi i recomend in the winter to be higher than that
then switch the car off and press the reset button for 5 seconds
check out the picture its the green arrow
then switch the car on caution will disappear
best wishes
thankyou i will look for it .
i do have a seperate set of tires and rims and they have sensors installed by resetting i take it this will recognise them
i have a message on dash saying go dealer
If you have a second set of TPMS on your winter tires they must be "registered" with the car's computer to be detected. When you change back to summer tires a re-registration for them will also be required. This has to be done at the dealer.
From: Vancouver Island, BC -ex Illinois &Toronto, ON
Hey VancouverL!
Yup, you will have to live with the warnings until you put your summer rims back on as there is no easy way to reset.
I went with winter rims and considered paying for an extra set of TPMS until I heard a dealer visit was required to reset. I am two hours from dealer so did not want to have to do that twice a year (plus I believe there may be a $70 charge).
I can live with the loss of the compass display and the warning only flashes at the start (It goes away completely when I return to my garage where wheels are stored but is retriggered when I drive more that 15-20 KMs).
Does seem like poor implementation given Lexus' previous excellent reputation for electronics.
