2007 LS 460 22inch rim question
Hey Guys I need some help... I was wondering if anybody has put 22inch wheels on there 2007 LS 460? I put 22inch wheels on mine and they are rubbing (in the rear only)if I go over a bump or if I have 3 people or more in the car the tire size is 265 30 22. I don't know what I should to correct this issue does anybody have any suggestions?? Thanks in advance
Did you lower your car? I had the same issue with the Tanabe springs. Ended up replacing those with Megan Coilovers and it pretty much resolved my issue 90%. Now it only bottoms out if I hit a major bump going pretty fast. Its definitely the fender. Just get them rolled and it will resolve your issue. I can definitely see it on mine when they were installing the coilovers.
Hi all i just bought a used set of 22. Its 22x10.5 front and 22x12 rear. It sits a 1/4" over the fender. I drop mines right above the tires and completely shaved my rear fender and removed all my wheel liner. Yet its still rubs when i make hard turns or have passengers. Cant figure out where its rubbing now. Any help would greatly appreciated.
devious23
Wheels, Tires & Brakes Forum
04-15-05 10:59 AM
Seize
03-23-03 05:05 PM
