Best Tire for LS460
Subscribe
Apr 14, 2023 | 06:45 PM
  #151
Quote: What characteristics/differences make up EV tires compared to regular tires?
There are now dedicated “elec/EV” tire lines and they tend to have stiffer sidewall for the battery weight, more NVH treatment (asymmetrical grooves, interior foam), and rolling resistance improvements.
I have only used standard tires on the EVs. The difference in wear is probably due to the torque.
Reply 1
Apr 14, 2023 | 07:10 PM
  #152
Glad you like them!
Reply 0
Apr 15, 2023 | 08:31 AM
  #153
Quote: Now rocking the Pirelli P7 AS Plus 3. The difference between them and the 8 year old OEM Bridgestones is stark. The OEM tires were only down to 4/32, but on city speeds over rough roads I was second guessing the decision to buy this car.
The Pirellis smooth the ride out so much. Steering is crisper (still a land yacht, but not feeling like a car on bald tires).
They transmit so much less road impact noise into the cabin. Road noise is a lot less. Not quite W222 S-Class, but night and day difference from before. Very happy!
Who had them in stock?
Reply 0
Apr 15, 2023 | 08:39 AM
  #154
Quote: Who had them in stock?
They are currently backordered at Discount Tire for only $246 each.
But it turns out that Tirerack was recently acquired by Discount Tire which makes it really easy to ship to a DT location.
https://www.discounttire.com/buy-tir...lus-3/p/113778
https://www.tirerack.com/tires/pirelli-p7-as-plus-3
Reply 1
Apr 17, 2023 | 09:02 AM
  #155
Michelin Primacy Tour are the tires currently on my 2016 LS base I recently purchased with standard shocks. These have a late 2020 date code so I assume they were replaced in early 2021 most likely at around 30K miles. I cant compare to the OEM tires but these ride as smooth and quiet as anything I have ever experienced. Granted this is my first ultra luxury sedan but my previous 2012 GX also had Michelin's and also rode surprisingly smooth for a big truck based SUV.
Reply 0
Apr 17, 2023 | 10:05 AM
  #156
Those tires are good tires, I had them briefly on my S560, I returned them because the sidewall on the front tire was totally different than the back tire (staggered sizes) and they looked terrible, but I would have kept them if it weren't for that.
Reply 0
Apr 18, 2023 | 03:16 PM
  #157
Quote: Those tires are good tires, I had them briefly on my S560, I returned them because the sidewall on the front tire was totally different than the back tire (staggered sizes) and they looked terrible, but I would have kept them if it weren't for that.
Which tire and what sizes?
Reply 0
Apr 18, 2023 | 03:51 PM
  #158
Michelin Primacy tour 18" on my 2016 LS460
Reply 0
Apr 18, 2023 | 03:59 PM
  #159
Quote: Which tire and what sizes?
Michelin Primacy Tour...mine are 19s but 245 in the front and 285 in the rear
Reply 0
Apr 18, 2023 | 04:01 PM
  #160
What does the staggard size do for ride and handling?
Reply 0
Apr 18, 2023 | 05:03 PM
  #161
Quote: What does the staggard size do for ride and handling?
It helps handling, doesn't really have any impact on the ride.
Reply 0
Apr 19, 2023 | 07:56 AM
  #162
Hi guys. I have just purchased the Pilot Sport All Season 4 for my 17 RWD from Costco.
Noobie question since it’s my first car that came with TPMS: it seems like it’s required to have this service. Does it mean that Costco will do the whole job? I remember reading somewhere you need dealer to reset the TPMS on the computer after new tires are installed.
Thanks in advance.
Reply 0
Apr 19, 2023 | 08:08 AM
  #163
No programming should be needed. Your factory sensors typically last 12 years, then batteries begin to die. If one can replace them when replacing tires, it's most convenient. BTW, all (including spare) need to be replaced as one bad sensor battery will shut down the entire sensor system and give a dash light. Also, your original spare is outside of safe age. If you have full size spare, just put an old tire on the spare. Space savers also age out.
Reply 1
Apr 19, 2023 | 08:14 AM
  #164
Quote: No programming should be needed. Your factory sensors typically last 12 years, then batteries begin to die. If one can replace them when replacing tires, it's most convenient. BTW, all (including spare) need to be replaced as one bad sensor battery will shut down the entire sensor system and give a dash light. Also, your original spare is outside of safe age. If you have full size spare, just put an old tire on the spare. Space savers also age out.
thanks for the reply!
Reply 0
Apr 19, 2023 | 09:38 AM
  #165
Quote: Hi guys. I have just purchased the Pilot Sport All Season 4 for my 17 RWD from Costco.
Thanks in advance.
What they are requiring is the Service Kit not the actual sensor. They will replace the rubber grommet, valve core, and locking nut/ washer. You don’t want to risk a tire leak due to a leaking seal when it deteriorates down the road.
Reply 1
