460L Speedometer
Old Nov 15, 2007 | 03:26 PM
keek's Avatar
keek
Default 460L Speedometer
It seems to me that my speedometer is too optimistic.
The fantastic mpg first tipped me then I ran tests with the road side speed signs, then my hand held GPS.
Everytime the Lexus seems to be going slower than the speedo says. Something like at a real 70mph the GPS says more like 67.
ANyone else seen or experience this? I have not checked the mileage (via odometer).
keek
Old Nov 15, 2007 | 06:29 PM
LEX75110's Avatar
LEX75110
keek, I agree....@ 70mph I felt everyone was pulling away and it just seemed slow. I took a trip and set my GPS on the dash and found:
At 70 mph indicated I was actually going 68mph
at 80 mph indicated I was actually going 79 mph
I guess if I car run 90mph all the time everything will be correct.
I knows that throws off the mpg as well. I wonder if that is adjustable on my next service.
RT
Old Nov 15, 2007 | 06:41 PM
bsims_01's Avatar
bsims_01
Yeah, I've noticed that my speedo reads a bit on the slow side as well.
Old Nov 15, 2007 | 07:00 PM
RXSF's Avatar
RXSF
lol this seems to be a problem with all lexus cars.
on the bright side, your speeding ticket will be underestimated
Old Nov 15, 2007 | 07:44 PM
rominl's Avatar
rominl
exclusive matchup
the other way for me, it says 50mph but radar says 47mph
it's deviation on speedo, happens in every car model
Old Nov 15, 2007 | 10:08 PM
encore888's Avatar
encore888
Haha! But as rominl reports the speedo deviation happens on multiple models.
Old Nov 16, 2007 | 07:08 AM
keek's Avatar
keek
Default speedo
I've never had one this bad. My ls430 is pretty dead on.
Just bothersome knowing the speedo is faster than the car.
keek
Old Nov 16, 2007 | 07:33 AM
4TehNguyen's Avatar
4TehNguyen
wouldnt tire pressure have effect on it, lower pressures would affect the rotations per mph reading. That is how TPMS detect the pressure something to do with the rotations of the wheel during motion I believe
Old Nov 16, 2007 | 07:38 AM
luxury1's Avatar
luxury1
This is not unusual. Many cars experience the same thing. My last Benz (2004) was about 2-3 off.
Old Nov 16, 2007 | 09:02 AM
rominl's Avatar
rominl
exclusive matchup
i doubt that. so when the car is stop the tps won't detect the pressure? not really
Old Nov 16, 2007 | 09:16 AM
4TehNguyen's Avatar
4TehNguyen
http://en.wikipedia.org/wiki/Tire_Pr...itoring_System
according to wiki, indirect type TPMS are measuring wheel speed (which is already on the car for the ABS system anyways) and other measurements . While it isnt measuring a "pressure number" its comparing it to the other tires That checking of the differences b/t the tires is enough to alert the driver that something is wrong with a tire. Direct would be the direct measuring of pressure. Since at a stop the wheel speed of all tires is 0, therefore no differences b/t the 4 tires so nothings wrong. But lets say its detecting 4 wheel speeds (lets say 60 is the speed for correct tire pressure): 60, 60, 60, 55 then the system is going to flag that theres something wrong and youll eventually find the 55 tire is low on pressure. I think this is one of the reasons why cars dont tell you specifically which tire has the problem, because what if you had 55 55 55 60 how would the system know which tire has a problem since its just checking differences b/t tires
not sure what lexus uses.
Old Nov 16, 2007 | 12:04 PM
rominl's Avatar
rominl
exclusive matchup
that would be silly as well. so if all 4 tires gradually loses pressure to 25lb (which will happen) together with maybe 1-2psi difference, it will never say anything?
i am pretty sure that's not the case. on our sc430, when we put back the stock wheels after 3 yrs, the light turned on. i read and all tires were at 25lb. the light was on when the car was stopped or rolling. when we were at gas station, i pumped everytihng back up to 35psi, and the light turned off
i can't say for sure neither, but at least that's my experience on the sc430
Lavrishevo
Apr 16, 2015 07:49 AM
hypervish
RX - 1st Gen (1999-2003)
20
Oct 15, 2013 11:50 AM
Modeler
Hybrid Technology
47
Sep 2, 2008 02:41 PM
caymandive
Sep 1, 2007 05:21 PM
