460 Jacked
Old Jun 15, 2007 | 10:39 AM
Celsior Master's Avatar
Celsior Master
Default 460 Jacked
My friends dad just got his 460 stolen... here's my friends story...
My Dad recently changed his company car to the nice new lexus LS460. It's the fancy smancy car that does the autopark thingy and has the the cool keyless ignition feature that most new cars have. Here's a picture. Pretty friggin sweet ride!
So, one of his subordinates is leaving the country so they have a get together at a nice chinese restaurant close to my house. He shows up at 6:30 and they get out around 8:30 and when he gets out, his car is GONE! It's pretty nuts how his car could just dissapear like that with 1-2 security guards in that parking garage patrolling. That means ther was no way the windows could've been broken or the car hot wired. How the heck did they get into the car and let alone start it and drive it away? Only the next day when I did some research online did I slowly get an idea of how it might have been done.
CNET ARTICLE
Let's say you just bought a Mercedes S550, a state-of-the-art, high-tech vehicle with an antitheft keyless ignition system. After pulling into a Starbucks to celebrate with a grande latte and a scone while checking your messages on a BlackBerry, a man in a T-shirt and jeans with a laptop sits next to you and starts up a friendly conversation: "Is that the S550? How do you like it so far?" Eager to share, you converse for a few minutes, then the man thanks you and is gone. A moment later you look up to discover your new Mercedes is gone as well. Now, decrypting one 40-bit code sequence can not only disengage the security system and unlock the doors, it can also start the car--making the hack tempting for thieves. The owner of the code is now the true owner of the car. And while high-end, high-tech auto thefts like this are more common in Europe today, they will soon start happening in America. The sad thing is that manufacturers of keyless devices don't seem to care.
Now, one 40-bit code sequence can not only disengage the security system and unlock the doors, it can also start the car.
Antitheft systems get more sophisticated
Wireless or contactless devices in cars are not new. Remote keyless entry systems, those black fobs we all have dangling next to our car keys, have been around for years. While still a few feet away from a car, the fobs can disengage the auto alarm and unlock the doors; they can even activate the car's panic alarm in an emergency. First introduced in the 1980s, modern remote keyless entry systems use a circuit board, a coded Radio-Frequency Identification (RFID) technology chip, a battery, and a small antenna; the latter two designed so that the fob can broadcast to a car while it's still several feet away. The RFID chip in the key fob contains a select set of codes designed to work with a given car. These codes are rolling 40-bit strings, meaning that with each use, the code changes slightly, creating about 1 trillion possible combinations in total. When you push the unlock button, the keyfob sends a 40-bit code along with an instruction to unlock the car doors; if the synced-up car receiver gets the 40-bit code it is expecting, the car performs the instruction. If not, car does not respond.
A second antitheft RFID use is for remote vehicle immobilizers. These are tiny chips embedded inside the plastic head of the ignition keys, and they are used in more than 150 million vehicles today. Improper use prevents the car's fuel pump from operating correctly. Unless the driver has the correct key chip installed, the car will run out of fuel a few blocks from the attempted theft. (That's why valet keys don't have the chips installed; valets need to drive the car only short distances.) One estimate suggests that since their introduction in the late 1990s, vehicle immobilizers have resulted in a 90 percent decrease in auto thefts nationwide.
Unfortunately, the companies making RFID systems for cars don't think there's a problem.
But can this system be defeated? Yes
Like vehicle immobilization, keyless ignition systems work only in the presence of the proper chip. Unlike remote keyless entry systems, keyless ignition systems are passive, don't require a battery, and have much shorter ranges (usually six feet or less); instead of sending a signal, the keyless ignition system relies on a signal emitted from the car itself. Keyless ignition systems allow you the convenience of starting your car with the touch of a button without removing the chip from your pocket or purse or backpack.
Given that the car is more or less broadcasting its code and looking for a response, it seems possible that a thief could try different codes and see what the responses are. Last fall the authors of a study from Johns Hopkins University and the security firm RSA used a laptop equipped with a microreader. They were able to capture the code sequence, decrypt it, then disengage the alarm and unlock and start a 2005 Ford Escape SUV without the key; they even provided an online video of their "car theft." But if you think that such a hack might occur only in a pristine academic environment, with the right equipment, you're wrong.
Real-world examples
Meet Radko Soucek, a 32-year-old car thief from the Czech Republic. Using a laptop and a reader, he is alleged to have stolen several expensive cars in and around Prague. Soucek is not new to auto theft; he has been stealing cars since he was 11 years old, but he recently turned high-tech when he realized how easily it could be done. Ironically, what led to his downfall was his own laptop, which holds evidence of all his past encryption attempts. With a database of successful encryption strings already stored on his hard drive, he's now able to crack cars he's never seen before in a relatively short amount of time.
And Soucek isn't an isolated example. Recently, soccer player David Beckham had not one but two custom-designed BMW X5 SUVs stolen, the most recent theft occurred in Madrid, Spain. Police believe an auto theft gang using software instead of hardware pinched both of Beckham's BMWs.
Gone in…a few minutes?
How a keyless car gets stolen isn't exactly a state secret; much of the required knowledge is Basic Encryption 101. The authors of the Johns Hopkins/RSA study needed only to capture two challenge-and-response pairs from their intended target before cracking the encryption. In an example from the paper, they wanted to see if they could swipe the passive code off the keyless ignition device itself. To do so, the authors simulated a car's ignition system (the RFID reader) on a laptop. By sitting close to someone with a keyless ignition device in their pocket, the authors were able to perform several scans in less than one second without the victim knowing. They then began decrypting the sampled challenge-response pairs. Using brute-force attack techniques, the researchers had the laptop try different combinations of symbols until they found combinations that matched. Once they had the matching codes, they could then predict the sequence and were soon able to gain entrance to the target car and start it.
In the case of David Beckham, police think that the criminals waited until he left his car, then proceeded to use a brute-force attack until the car was disarmed, unlocked, and stolen.
Hear no evil, speak no evil
To remediate these hacks, the authors of the Johns Hopkins/RSA study suggest that the RFID industry move away from the relatively simple 40-bit encryption technology now in use and adopt a more established encryption standard such as the 128-bit Advanced Encryption Standard (AES). The longer the encryption code, the harder it is to crack. The authors do concede that this change would require a higher power consumption and therefore might be harder to implement, nor would it be backward compatible with all the 40-bit ignition systems already available. The authors also suggest that car owners wrap their keyless ignition fobs in tin foil when not in use to prevent active scanning attacks, and that automobile manufacturers place a protective cylinder around the ignition slot. This latter step would limit the RFID broadcast range and make it harder for someone outside the car to eavesdrop on the code sequence.
Unfortunately, the companies making RFID systems for cars don't think there's a problem. The 17th annual CardTechSecureTech conference took place this past week in San Francisco, and I had an opportunity to talk with a handful of RFID vendors; none wanted to be quoted nor would any talk about 128-bit AES encryption replacing the current 40-bit code anytime soon. Few were familiar with the Johns Hopkins/RSA study I cited, and even fewer knew about keyless ignition cars being stolen in Europe. Even Consumer Reports acknowledges that keyless ignition systems might not be secure for prime time, yet the RFID industry adamantly continues to whistle its happy little tune. Until changes are made in the keyless systems, my next car will definitely have an ignition key that can't be copied by a laptop.
Old Jun 15, 2007 | 10:46 AM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
damn dude, that sucks, good luck trying to find it.
Old Jun 15, 2007 | 10:55 AM
dimapb's Avatar
dimapb
With all of the gadgets in the car, such as Lexus Link, they should be able to find the car w/in a few minutes.
Old Jun 15, 2007 | 11:19 AM
luxury1's Avatar
luxury1
Depending on the parking lot it might have also been towed away. This has been another somewhat common way of stealing cars.
Old Jun 15, 2007 | 11:23 AM
Gojirra99's Avatar
Gojirra99
Towed away ? I hope not with the security guards present in this case LOL ...
Old Jun 15, 2007 | 11:51 AM
Johnny's Avatar
Johnny
Hmmm... A small keyfob slip-on holder, with an EMF grid sown-in might be the next trendy fashion statement.
Investment opportunity?
Old Jun 15, 2007 | 05:53 PM
joedaddy1's Avatar
joedaddy1
what is going on? y is that article involved?
ur car is @ the tow yard
Old Jun 15, 2007 | 10:00 PM
rominl's Avatar
rominl
exclusive matchup
umm, dunno, the article that he found on the internet, i remember reading it elsewhere, i believe people said it's sort of urban legend as it's very hard to do.
either way, very sad
Old Jun 16, 2007 | 05:01 AM
gatorcb's Avatar
gatorcb
It's no hoax....http://www.jhu.edu/news_info/news/ho...an05/rfid.html
The mobil speedpass device is suspectible as well. 40-bit encryption with todays computers (high powered laptop) should be able to cracked in minutes. That's why you see websites use 128 bit encryption
Old Jun 16, 2007 | 06:32 AM
luxury1's Avatar
luxury1
Security guards are usually not much smarter than my shoe... There was one that occassionally "guarded" my building in the city. He was about 80 and was asleep most of the time
R Z
Oct 21, 2015 10:28 AM
sarantis
Jan 30, 2014 11:41 AM
GAM3OVR
Aug 21, 2010 01:28 PM
PhilipMSPT
Feb 2, 2007 07:22 PM
dfiorito
Nov 20, 2006 11:56 AM
