Code P2610
Old Jan 17, 2026 | 03:10 PM
chrispap's Avatar
chrispap
Default Code P2610
New member here, with a 2007 Lexus 460. I just bought the car from a relative. I just finished replacing both high-pressure fuel pump gaskets on the valve cover, when I got this code. The relative said the code came on for him too, so I don't think it has anything to do with my repairs.
I searched the forums and tried the usual remedies (gas cap, check battery voltage, tighten the cables, etc., although I do not see how these can cause the code). The most plausible cause seems to be an ECU internal problem that requires replacement of the ECU (ouch).
I have a Foxwell 530 scanner and can observe live data if needed. I also saved freeze frame data, if someone knows what I should look at.
Is it really the ECU or are there other things to try? Would Techstream give me more clues?
Old Jan 18, 2026 | 10:24 AM
93MSB's Avatar
93MSB
The service manual says there is no diagnostic procedure. P2610 refers to internal ecu error, the remedy is to replace the ECU
https://charm.li/Lexus/2007/LS%20460...0Charts/P2610/
However, here's a thread that indicates a low battery could cause this
https://www.clublexus.com/forums/gs-...ode-p2610.html
Old Jan 18, 2026 | 11:18 AM
chrispap's Avatar
chrispap
Thanks, I saw both of those (that's what I meant when I said I checked battery voltage). I was hoping that someone had more options that I could try. The manual also suggests checking the wiring.
I will try removing/cleaning/reseating the connectors on the ECU and see if that helps.
Kaianuanu
Oct 1, 2025 04:20 AM
ACP84
NX - 1st Gen (2015-2021)
Feb 11, 2022 08:40 PM
topgun129
Jul 8, 2014 05:20 AM
chi123
Maintenance
Nov 4, 2012 12:13 AM
