Question About Brake Fluid Change Intervals
Old Oct 6, 2025 | 04:05 PM
JRA2000TL's Avatar
JRA2000TL
Default Question About Brake Fluid Change Intervals
I'm staying on top of the brake flushes since I bought my 14 LS March of last year. Bought it with 84k, and at 87k I had Lexus change the fluid. That was on 8/18/24. The car now has a little under 94k, but it's been just over a year. I didn't think about it when I just had the oil changed at Toyota. Would it be ok to wait until Feb when it's due for another oil change (by time, not mileage)? Some have said 6 month intervals, some 1 year, others say max 2 years. I bought some of the brake fluid test strips that The Car Care Nut recommends. Just checked it now and it's on the very light pink 10ppm on the scale---basically almost new. Test kit says change at 200ppm or more. Since this is basically the next level above 0, it looks to be ok if I wait until Feb. Yes, I know I can do it myself; but it's not worth the hassle, and I hate dealing with fluids because I always manage to make a mess. The older I get, the less fun working on cars has become.
The whole point of this is prolonging the brake actuator life. Looks like it was done at 60k before I bought it, but since it's still fine, I want to keep it that way.
Old Oct 6, 2025 | 04:13 PM
Anfanger's Avatar
Anfanger
Every 2 years is a safe interval, unless test strips show that more frequent changes are required.
Old Oct 8, 2025 | 01:12 PM
BB9's Avatar
BB9
If you have brake fluid tester you can figure better schedule for your particular car but general consensus for is once every 2-3 years for the brake fluid and twice a year for the engine oil if you driving less than 10K miles per year. I did my first brake fluid change when my car was 5 years old (30K miles), but my car came from relatively dry area and it was OK.
Old Oct 8, 2025 | 05:45 PM
Oro's Avatar
Oro
An unconventional but easy and effective method is to change the reservoir volume 1x a year. This will cut water content and any potential contaminant by about 1/2. Just drain or siphon out the reservoir contents, and re-fill.
Old Oct 8, 2025 | 06:33 PM
Zetascry's Avatar
Zetascry
This is a really easy way to replace fluid. Just drive a few hundred or thousand miles then repeat 2-3 times to get the fluid mixed up real good. But it will not do what a real air bleed procedure using techstream would do. I would have the dealership perform this and give them my choice of fluid brand.
Old Oct 8, 2025 | 08:25 PM
Oro's Avatar
Oro
True, but: if you haven’t done something to introduce air into the system, bleeding isn’t necessary. And if you do this annually, you rarely ever need to bleed except when replacing/rebuilding calipers. It usually takes just a few days to fully mix - it will mix just sitting still because of Brownian motion. But driving will speed it up a lot, of course. Iv’e tested it w/pH strips and it stabilizes (meaning fully mixed) in 2 or so days of driving, or about a week of sitting.
If you start with a new or new-ish car, or rebuilt calipers, you can get away with this for a LONG time. I’m so glad I learned this a long time ago (c.2010) and hope it can help some folks.
Biggest advantage is for people who won’t bleed brakes, or have a lot of cars, they can do this and it helps A LOT. Much better than doing nothing, which is the default for a lot of people.
Old Oct 8, 2025 | 09:08 PM
I always purge the lines because old fluid in them will kill things, I also only know what 3 of my cars had as far as maintenance for sure so ALL the others I full flushed.
Shaboom
ES - 7th Gen (2019-2025)
Oct 3, 2023 10:27 AM
Amphibulus
21
Dec 11, 2018 03:36 AM
ziggman
Sep 8, 2017 08:57 PM
15951
Suspension and Brakes
Sep 20, 2009 05:37 PM
jayy178
CL of Southern California
Aug 21, 2009 06:01 PM
