2007 LS 460L Continuous unresolved Engine code problems
Old Jun 15, 2025 | 09:31 PM
HowardHJS's Avatar
HowardHJS
2nd gear
Default 2007 LS 460L Continuous unresolved Engine code problems
Been real Challenging.
Most codes related to Air Fuel Ratio , Oxygen and Crankshaft Sensors and VSC warnings-Take to your dealer
Latest Code P2237 O2 Sensor 1 Bank 1.
Attempted resolutions
Replaced Bank 1 Air Fuel Ratio and Bank 2 Air Fuel Ratio Sensors
Replaced Oxygen Sensors Bank 1 Sensor 2 and Bank 2 Sensor 2
Replaced Crankshaft Sensor Prior efforts replaced all spark plugs and coils
Replaced Battery and Alternator a month ago.
After replacing the four Air Fuel Ratio and Oxygen Denso Sensors today, I reset and cleared all codes.
Now Bank1 Sensor 1) is back (original code problem)
Has anyone had and resolved this problem? Can't smog and register the car as a result.
I' thinking nwxt to replace the ECU. Any feedback is appreciated. Thank you
Old Jun 15, 2025 | 11:38 PM
Unless you have harness damage (rodents or accident) then the ECU is probably your next logical repair attempt. Were all parts replaced OEM?
Old Jun 16, 2025 | 09:40 PM
HowardHJS's Avatar
HowardHJS
2nd gear
Hello and Thank you. I made an error in my post. I replaced one Air fuel ratio sensor with genuine Toyota and the other Air Fuel ratio Bank 2 sensor 1 with a Denso sensor. I replaced both bank 1 sensor 2 and bank 2 sensor 2 with Denso sensors. Could there be an incompatibility issue?
I also have the VSC std warning but have no other error codes than Bank 1 sensor 1 again P2237 as I stated. Appreciate your input. Thank you
Old Jun 16, 2025 | 09:47 PM
Depends on if your parts were in fact made by Denso. If you buy on Amazon they are probably counterfeit, Ebay isn't any better.
Old Jun 17, 2025 | 01:12 AM
Check live data before throwing parts like that......
Bumbobee
Oct 22, 2022 10:29 AM
2ks
RX - 1st Gen (1999-2003)
78
Jun 13, 2020 08:21 PM
symone
GX - 1st Gen (2003-2009)
15
Jun 1, 2014 08:17 PM
bearbrew
Dec 14, 2009 10:07 AM
mr. aristo
15
Apr 6, 2006 09:41 AM
