Help With Upper Control Arms
Old May 5, 2025 | 04:22 AM
jbtvt's Avatar
jbtvt
For AWD
When I did it I measured height from center of wheel hub to bottom of fender arch, using a small level, before starting anything. Removed and reassembled everything hand tight with vehicle on jack stands, then used level again and a jack under the wheel hub to get it to the same ride height, then torqued. Removed air suspension so didn't have that step. Bottom control arms you don't even have to remove the wheel to access easily, just the uppers. Had to retorque after alignment when checking things because the shop only torqued to about 30 ft lb instead of 155, and for that I just put the jack under the tire itself.
Old May 5, 2025 | 11:27 PM
Marc780's Avatar
Marc780
Thanks for that answer, a great answer!
ntts
Dec 2, 2021 01:40 PM
Jason12327
Sep 10, 2018 08:33 PM
Raydlaw
May 9, 2018 01:33 AM
downrigger
Dec 5, 2013 10:59 AM
AnimalB
Suspension and Brakes
Aug 8, 2012 06:56 AM
