High Pressure Fuel Pump leak
Hello,
I got high pressure fuel pump leak from the area like in the movie (dumper valve rubber nipple). I wonder if I can some how fix it instead of replacing the whole pump.
You can replace just the damper; make sure that you release fuel pressure before before removing the part. To release fuel pressure, you can disable the main fuel pump and run the car until it stalls.
Removing the fuel pump relay should allow that unless computer will not allow you to start engine. You will have to find out!
The fuel management system will prime the system, it might take couple tries to start the vehicle and you likely will get a light about engine failing start. You can just clear the error once the system primes itself to the correct pressure.
Moos0004
GS F (2016-present)
14
Jan 23, 2024 09:27 AM
mikemu30
ES - 7th to 8th Gen (2019-present)
Jul 31, 2023 09:30 PM
