Repeated Whirring noise after switching on A/C
My 2009 LS460 is making a repeated whirring noise which is particularly noticeable when stopped or at low speeds only after switching on the A/C. Also the rpm moves ever so slightly in sync with the noise especially at idle.Sound goes if i switch the A/C off. Found another post with the same issue on a gs460 and i have attached the YouTube clip that user had attached.
the car has a fault stored in history related to the servomotor circuit for the air inlet and outlet damper control in the front
no luck with the sound. checked cabin filter and other things mentioned here but no luck. my ac tech said there was a slight variation in compressor pressure in tune with the sound but could not find the reason. let me know if you are able to figure it out
I have this on my 2017 LS460, same symptoms (i.e., whirring only happens when A/C is on and goes away the minute I turn off the A/C). After hours of looking into it, I've come to the tentative conclusion that it is an engine noise. in other words, the ever so small tax that the A/C puts on the engine causes the engine to make the whirring noise. Let me explain.
I opened up my glove compartment and removed the cabin air filter, exposing the A/C fan. I ran my car with the A/C fan exposed for about 15 minutes until the noise started with the A/C. Putting my ear right up to the open A/C fan, the fan itself was silent. Zero noise from the fan. Turn off A/C and the whirring noise goes away. Turn on A/C, whirring starts. but no noise at all from the A/C fan.
I open up the hood and repeat the process. Can't hear the whirring in the engine bay because it's too loud. When I turn the A/C on, the noise in the engine bay slightly changes. I think this slight change produces the whirring sound inside the cabin.
That's all I got. but I think that's what's happening.
Any other thoughts?
Any other thoughts?
