Hi All,
First time posting to this forum - THANK YOU for having such a place.
The left turn signal flasher started going too fast so I assumed that the flasher was bad. I bought a fresh one from a dealer. Through grit and determination (certainly not skill) I got the old one out and replaced with new. All good, right? After driving for about 5 minutes the left turn signal was blinking too fast again, right turn signal is normal??? Help!
I know that it is not affecting how the car drives but I'd like to fix. I have done no modifications to the vehicle.
I just found out this morning that if your battery's almost dead all the signal lights flash fast, had the car on a ctek mxs 5.0 for about 3 weeks and all the lights were on like it was charged but it would barely turn over. piece o crap
Well, after looking through different part sources - it does not seem like these bulbs are replaceable? Does that sound correct? As they are integrated with the headlight assembly.
Does your car really use 81980-50030 flasher relay? I thought it was an integrated flasher. If it does then can always modify the flasher so it doesn't care about load.
