Fuel temp sensor sor
Old Dec 19, 2024 | 06:17 AM
Thackerdavid's Avatar
Thackerdavid
4th Gear
Default Fuel temp sensor sor
Has anyone had to replace the fuel temperature sensor. The dealership is wanting 20 hours to replace. Is it that difficult. If not where can I find directions to change myself
Old Dec 19, 2024 | 06:45 AM
Gerf's Avatar
Gerf
Do you mean the pressure sensor for the direct injectors? If so, it's under the intake manifold so if you look at a thread for repairing the valley plate leak that is the procedure you will have to follow to get to the sensor, that would be an ideal time to do the valley plate reseal if that's your problem.
Was there a trouble code that was diagnosed and a replacement was recommended?
Old Dec 20, 2024 | 06:02 AM
Thackerdavid
4th Gear
Po546 is the code. The dealer called it a fuel temp modulator
Old Dec 20, 2024 | 07:07 AM
Gerf's Avatar
Gerf
The code P0546 refers to exhaust temperature sensors and unless you have a 600H you don't have them.
https://www.obd-codes.com/p0546#google_vignette
Old Dec 20, 2024 | 07:31 AM
Gerf's Avatar
Gerf
This might help you out.
https://www.clublexus.com/forums/ls-...s-600hl-6.html
Old Dec 20, 2024 | 10:20 PM
Thackerdavid
4th Gear
I do I have a 2009 lexus LS 600hl pebble beach edition. Have you changed one of these before
takadakeyo
Feb 14, 2021 11:36 AM
mzeitlin
Jan 13, 2020 12:41 PM
is350sppkg
Nov 21, 2015 11:10 AM
350stew
Oct 23, 2013 05:31 PM
