Transmission mount change
Old Sep 28, 2024 | 03:15 PM
Pattersom's Avatar
Pattersom
10th Gear
Default Transmission mount change
Just finished up changing the transmission mount. Car is a 2010 with only 45,000 miles but the vibration when stopped in drive was annoying so decided to try something.
thanks to the person who posted a great DIY. Easy job. Did it while replacing oil. The bolts that hold the mount to the chassis are the tough ones. A little awkward to get at. Need a universal joint.
https://www.clublexus.com/forums/ls-4th-gen-2007-2017/960781-diy-transmission-mount-aka-rear-engine-mount.html
did it help? I think so. Will need to drive it some more. But a strong maybe.
interesting note, the mount is oil filled. Wasn’t expecting that. Could explain why mileage was low, but 14+ years caused the oil to degrade and cause vibration.
Old Sep 28, 2024 | 05:07 PM
Gerf's Avatar
Gerf
Vibration when idling in drive would make me think it's the engine mounts and you should notice a difference right away. The trans mount is more likely to need a test drive to confirm the repair.
Old Sep 28, 2024 | 06:04 PM
You likely need engine mounts
AZGS4
Jun 28, 2025 12:33 PM
thriftyshi
May 4, 2019 01:47 PM
Eds98LS
Mar 13, 2013 04:51 AM
worldforgo
Oct 31, 2011 01:31 AM
djl
Aug 9, 2004 12:27 PM
