Replacing a new Cat system help 07 LS460
Old Aug 2, 2024 | 09:49 AM
Mrcoach's Avatar
Mrcoach
Default Replacing a new Cat system help 07 LS460
Seeking recommendations for replacing catalytic converters on a 2007 LS460L with 136,000 miles. Previous error codes include PO430, PO420, PO137, and PO328. Reliable and cost-effective sources for the parts and labor are appreciated. Would purchasing from a junkyard or discount parts store be a sensible option? How much can I expect to pay for this replacement?
Old Aug 2, 2024 | 11:22 AM
Bovineplan's Avatar
Bovineplan
One cat failing i could beleive. Both failing at the same time can happen but usually if both codes are on something upstream is the issue. Something that affects both banks. More so if both codes came on at about the same time.
Good luck.
Old Aug 2, 2024 | 12:46 PM
Mrcoach's Avatar
Mrcoach
I’m so confused right now I’ve had a PO420 and a PO430 on at the same time unfortunately when I replaced the battery last week everything cleared but now just PO430 is on. Thanks for the input
Old Aug 2, 2024 | 01:15 PM
Gerf's Avatar
Gerf
You probably have a small exhaust leak somewhere in your intermediate pipe before or at the o2 sensor/s
Old Aug 2, 2024 | 02:06 PM
Check for exhaust leak
Check to make sure the actual sensors are working correctly
Make sure you aren't just burning so much oil you killed the sensors or cats
Old Aug 2, 2024 | 05:32 PM
Cavedog's Avatar
Cavedog
Same problem. I kept replacing the gaskets between the cats and exhaust. Advance auto kept selling me a thin approx one eight inch thick crush gaskets. They lasted for a year and had the problem over and over again. I researched and found the proper gasket is Fel Pro 61460. They are much thicker and tapered approx three eight inch. No more codes shown for years.
Old Aug 4, 2024 | 01:27 PM
Mrcoach's Avatar
Mrcoach
Thank you for your help
Old Aug 4, 2024 | 01:28 PM
Mrcoach's Avatar
Mrcoach
I appreciate your help
Old Aug 4, 2024 | 01:29 PM
Mrcoach's Avatar
Mrcoach
Thanks so much
dansonted
Oct 4, 2023 10:12 PM
LANewsboy
Feb 13, 2023 10:49 PM
LSF12
May 25, 2017 10:22 AM
ychachad
Mar 16, 2009 07:37 AM
GSXOTIC
13
Sep 23, 2008 10:08 PM
