Aux died in my 07
Old Mar 17, 2024 | 08:47 PM
FlexnLexus's Avatar
FlexnLexus
Default Aux died in my 07
Does anyone know how to go about fixing the aux issues in these cars? The plug has gotten looser over time, and would sometimes cut out.
If I wiggle the cord a bit, it would work again, but now there’s no signal at all from the plug.
I tried changing modes on the steering wheel which didn’t work.
Old Mar 17, 2024 | 11:17 PM
This should work
Amazon Amazon
Old Mar 18, 2024 | 09:41 AM
Protholl's Avatar
Protholl
Originally Posted by LeX2K
FWIW the description of this says LS460 but Amazon confirmed fit says it does not fit my 2008 LS460. I clicked the part listed just left of it and it no longer flags it. I'm going to buy one just in case I have the problem. Thanks!
Amazon Amazon
Old Mar 18, 2024 | 10:55 PM
FlexnLexus's Avatar
FlexnLexus
Great thanks! I bought one earlier today. BTW is it easy to install? Do you just pop the old one out?
Old Mar 19, 2024 | 01:49 AM
It pops out, swap connector and you're done. Replaced a few of these on Toyota's your car will be the same deal.
FYI the original part number is 86190-53010 this fits various years of Prius, ES, LS, Camry and others.
Old Mar 19, 2024 | 03:48 AM
evansj's Avatar
evansj
An identical looking part (from Aliexpress) worked fine in my 2008 LS600hL. I found that the plastic moulding of the original was better than the replacement so I swapped the new PCB into the old case and it worked fine.
Old Mar 19, 2024 | 10:15 PM
FlexnLexus's Avatar
FlexnLexus
It worked, now I can stream music from my phone again. Thanks guys.🫡😎
- V -
Dec 6, 2023 01:37 PM
Stoodo
ES - 7th Gen (2019-2025)
Jan 8, 2022 11:36 AM
jjc250
May 18, 2015 09:39 PM
Neil4Speed
May 3, 2012 01:13 PM
