New Brake Actuator installed, not clearing codes......
I have an independent mechanic install a used OEM brake actuator I purchased. He bled the brakes, ran it through Techstream, codes didn't clear.
Figuring it was a bad brake actuator, I purchased a brand new one, mechanic installed, codes STILL not cleared. On top of that, there is an audible beeping noise that happens periodically. Has anyone heard of this happening before? I'm $2,500 in the hole with ABS codes not clearing. |
Did you use your VIN when ordered those actuators? There are numerous variations and they have to be exact match to your car. It is possible to buy that actuator for your year and model and still get the wrong one. Also, there are few different software options.
Originally Posted by BB9
(Post 11636788)
Side note: TPMS sensor light came on too, probably not connected but worth mentioning. I did not know there were different variations, haven't seen that in the search on this forum. I guess I'll bite the bullet and take it into Lexus. |
Last post, bye all
Gentlemen! Too much. We have NO data whatsoever. What codes? What year even? What module was installed? It's part no? Pictures of anything?
Let's ask questions first, theories later. Merry Christmas everybody! |
Originally Posted by Boykie
(Post 11637018)
Let's ask questions first, theories later. Merry Christmas everybody! 2007 LS460. ABS lights showed up on instrument cluster. Very common issue on LS460. Scanned by mechanic. It's a bad brake actuator. Replaced actuator twice and the ABS warning lights still show up. UPDATE: I have since talked to a Lexus mechanic about it. He basically said the mechanic must perform a "linear valve offset" after bleeding the brakes through Techstream "in order for codes (warning lights) to go away." He said to take it in to a Lexus, have them run a diagnostic, they will probably bleed the brakes and if that doesn't clear it, try to sell me a new actuator. |
It's sounds like Lexus mechanic is saying the shop who did the work, didn't finish the job correctly. Have you talked to the shop with this "accusation" yet? They should stand behind their work. Is this a case of "if you think a pro is expensive, see how much an amateur costs you in the end"? There are indie shops who are competent in Lexus. I do wish you a full resolution at the least cost.
Originally Posted by swfla
(Post 11637749)
I'll update after taking the car into Lexus on Saturday. I'm pretty nervous. Thanks for all the help guys. |
Everything sounds good so far. Hoping a proper Techstream session will solve the issue. So many repairs on Lexus require Techstrean software to complete the job.
Typical. That's why many here say to replace everything, if it's ran a long time with the actuator bad it kills everything else.
Too bad it turned out to be a second component as well. You had no idea, that happens to members here as well. Hope it's smooth braking from here on out. Glad you shared the outcome.
Originally Posted by Sportznuts
(Post 11636784)
Figuring it was a bad brake actuator, I purchased a brand new one, mechanic installed, codes STILL not cleared. On top of that, there is an audible beeping noise that happens periodically. Has anyone heard of this happening before? I'm $2,500 in the hole with ABS codes not clearing. I had got a letter in the mail from Lexus regarding the ABS. It said if the ABS light is on, then to bring it in to get checked and they will repair it free of charge but if the sensor is showing due to something else then the repairs would not be covered. I brought it in and they told me that it is covered and they will repair it, but warned me after they repaired it, the ABS light can still come on, and if it does, it is the ABS fuse. They said since the ABS light is on, the system would still run and can cause a failure on the fuse, but would have to replace the whole Junction Fuse box, and this will not be covered. They said this has happened to a few people already. I just got the call today and they said that its been repaired, but the light came back on and i would have to replace the Junction Fuse box and charged $800 for the part and Labor |
A cautionary tale for others. it ain't always over after a repair. Thank goodness we don't hear this a lot.
(Post 11641854)
