Transmission Fluid
Old Mar 6, 2024 | 10:35 AM
  #31
Boykie's Avatar
Boykie
Engine must be on! Also don't forget to move shifter thru ranges couple of times while holding brakes. Stop engine only after adjusting fluid and closing plugs.
You have severe underfill (liquid drains to pan when off).
Old Mar 6, 2024 | 07:00 PM
  #32
Originally Posted by dan25man
Hey, just for my own mental sanity. When doing the transmission fluid re-leveling is the engine supposed to be on or off?
I did: plug holes, add fluid, start engine and warm to 35-42C, then I stopped the engine, and opened the drain plug, now getting shifting issues like it's underfilled? Someone at work said the engine should be running for the system to have pressure, else with it off the system/torque converter drains. I probably have it underfilled?
You have an insane underfill.
The process is extremely simple yet somehow everyone always messes it up or thinks that is complex. Once again I'll write it out....
Put pan and filter back
Fill pan as far as you can with engine OFF
Connect scan tool
Key on engine off
Find trans temp value in data stream
Turn engine on
As fast as possible fill till overflow
Cycle through all gears, wait 15 sec each
Fill again
Rev to 2000 for 20 seconds
Fill again
Wait for temp to hit 104* (check this, I'm writing from memory and it might be different)
When temp hits spec make sure overflow is just a slight stream
Close all plugs
Shut down engine
Key on engine off
Clear TCM memory
Command relearn state
Key off
Start engine
Go drive
Do 5 0-70 nice and slow accelerations
Do 5 70-20 coasts
Do 2 0-130 full hammer runs
Old Mar 7, 2024 | 07:15 AM
  #33
JohnnyC407's Avatar
JohnnyC407
Toyota/Lexus uses a machine to exchange the fluid. Just take it in and don't worry about it. Do it every 50-75k miles and you'll be fine.
Like others have said. You can change it yourself. But if you screw up it's on you and I personally don't want to take the chance when the cost is low to have Toyota do it for me.
Whatever you do don't do a 0-130. That's a great way to wind up in County and possibly lose your car/license.
Old Mar 7, 2024 | 07:22 AM
  #34
And since they don't change the filter you risk starving the pump. You need to replace the filter whenever you change fluid or you may encounter issues as many other threads have gone over here.
Old Mar 7, 2024 | 08:27 AM
  #35
JohnnyC407's Avatar
JohnnyC407
They change the filter too.
Old Mar 7, 2024 | 02:08 PM
  #36
No they don't unless you pay extra/ask, if you request trans fluid they just do fluid.
Old Mar 8, 2024 | 06:22 AM
  #37
JohnnyC407's Avatar
JohnnyC407
Old Mar 8, 2024 | 08:52 AM
  #38
It's part of the TOYOTA procedure. Not sure what they did at your former dealership but that's the requirement. What position did you have there?
I've just seen dozens of customer cars that have trans service in their history and the factory pan seal and filter is still there. A fluid change at a dealer doesn't include the filter unless you pay extra for it and many do not even want to touch transmissions at all.
Old Mar 8, 2024 | 09:01 AM
  #39
Boykie's Avatar
Boykie
+1, aa80 filters are rarely even stocked. If client wants - overnight from central tmc warehouse. We call it 'strainer' as it's not much of a real filter.
Old Mar 8, 2024 | 11:19 AM
  #40
Exactly, stateside ours actually are fleece filters though.
Old Mar 8, 2024 | 06:11 PM
  #41
Cavedog's Avatar
Cavedog
I had the fluid change at 160k. At a Toyota dealer. It looked like mud. Never had a problem, worked good to the day I traded it off.
P5mmx10g
NX - 2nd Gen (2022-current)
Dec 28, 2023 11:44 AM
silver250
Aug 13, 2021 02:32 PM
surflife5
Maintenance
24
May 26, 2007 07:30 PM
