Wing morror
Hello,
The drivers side wing mirror does not retract, everything else works.
I think perhaps in the past a car has hit it and it has home really back??
I don't want to buy a new mirror but been told can replace the wire or metal wire?
can you advise please or give me a part number.
Also is it easy to open up?
thanks
thanks
It is not easy.
Here's the parts needed.
https://www.ebay.com/itm/354559832356?var=623940134896
Motor replacement here.
https://www.clublexus.com/forums/ls-...l#post10999864
More pictures of mirror removal here.
https://www.clublexus.com/forums/ls-...l#post10989347
https://www.clublexus.com/forums/ls-...l#post10993899
It is not easy.
Everything works on the existing mirror, and you can hear the motor working too, it sounds like the cable or connector lead has snapped or unclipped when the mirror was forced right back.
Looks quite complicated as I cannot do this kind okind of work.
How easy is it to open up the mirror?
Thanks
L
You might get lucky. There are a few screws that are known to come loose. If you hear your motor trying to retract / extend I believe you just need to add some thread lock to the screws and tighten them up. You don't need to remove the mirror from the car.
Thank you that is what am thinking
Sound like the plastic claws are worn down..
just like the things in a clock to make motion.
If I was you buy online a working mirror and sell yours online to get some $$ back cause not everyone cares about the folding mirror.
It getting someone to.look at the mirror first, but happy folding this manually for the time being, all the others features all work
Ebay is a good source for used mirrors and mirror parts. Finding the right color and the correct options sometimes is a waiting game. Considering the cost of labor, it is usually less expensive to replace the entire mirror. While there are electrical wires inside, no cables, only gears and electric motors.
If it bothers me will source one from eBay and take it from there.
