Audio system question
Old Oct 22, 2023 | 12:23 PM
chp7932's Avatar
chp7932
8th Gear
Default Audio system question
Hello,
New member here, first question. I just got a, new to me, 2012 LS460 AWD. It has the stock audio system (not ML). Did a google search and found the stock speaker sizes but would like to know more. Specifically looking for the types of speakers used (ie full-range vs frequency-specific) in the front doors, power level of the amp and how it's used and whether the amplifier uses active crossovers, what are their frequencies and slopes.
Thx
Old Oct 22, 2023 | 12:50 PM
swfla's Avatar
swfla
Congrats. There's no accurate info available as it's all proprietary. Changing an amp is a major undertaking. If you wish to upgrade the speakers, high efficiency is the only way to go. I suggest Crutchfield.com as a good place to find speakers that will fit. Usually lots to choose from. Most members here recommend buying a car with the Mark Levinson system if great sound is important to you. I know you already have this car, just telling you what members here advise.
Old Oct 22, 2023 | 07:56 PM
Vtallysx4's Avatar
Vtallysx4
The amplifier has a built in DSP, it does all of the sound processing- time alignment, and filtering (it is a TON of processing). It also has a "loudness" setting permanently on, you will notice it when the bass suddenly gets louder and doesn't really go up with the volume after a certain point. There were changes in amplifiers between the years and some years can use a amplifier integration harness while others can't (in case that info helps you).
Edit: the front door speakers are not full range, they are meant to play lower frequencies.
Old Oct 23, 2023 | 07:53 AM
chp7932's Avatar
chp7932
8th Gear
I've decided to go all the way and replace everything except the head unit since it integrates everything and I don't want to change the stock look of the dash. I competed in IASCA (sound-off competitions) back in the mid 90s. I'm not interested in "rattling things" but I do want a clear front stage with adequate bass in reserve. I'll keep the interior look stock and use very little space in the trunk. I already have some components and will post pictures when finished. Should be done in the next 4 weeks.
Thank you for the quick replies.
Old Oct 23, 2023 | 09:07 AM
swfla's Avatar
swfla
Looking forward to your success and posting results will help others here.
Old Oct 23, 2023 | 09:08 AM
Vtallysx4's Avatar
Vtallysx4
If it helps, I went with a Helix V-eight mkii for the DSP and amplifying the speakers. It has 8 channels out, which was good for the dash and front doors to run active as well as the rear door point source speakers (rear fill). The DSP side of it has 2 extra outputs which you can use for subwoofer and a center channel amped separately. I never did run a center channel as I have a one seat tune, but, you can do a two seat tune if you replace your center channel as well as amplify it. Sounds phenomenal, I use morel 3 ways in the front and morel point source speakers in the rear doors, 2 12" audiofrog subs from a sundown 2k watt amp. Be aware, placement of the subwoofers in this car highly affects the sound, placed close to the wall separating the passenger compartment to the trunk, you would get a ton of cancellation and I got around that by building a wall around the back of the box to separate from the rest of the trunk, otherwise you couldn't tell there were any subwoofers back there without it. The doors are pretty well insulated, but I used Resonix to dampen and isolate further.
Old Oct 23, 2023 | 09:23 AM
chp7932's Avatar
chp7932
8th Gear
Thx for the comments Vtallysx4. I plan on using a single 12" in a small sealed box, remove the stock driver in the rear deck, point the 12"up, but not attach to rear deck, and also build a wall to hide everything. I want 3-ways in the front, 4" coax in the rear doors and center channel. All powered separately and actively crossed-over, except the 4" coaxes in the rear doors (as they be used for rear fill). I have a 5-channel and a 4-channel that will power everything. Haven't decided on a line converter,/dsp yet
Old Oct 23, 2023 | 09:50 AM
Vtallysx4's Avatar
Vtallysx4
They do have an amplifier bypass harness available, depending on the stock amplifier in your trunk (Lexus changed it in certain years). You can use the bypass harness to tap the signals you need without cutting anything up, as a heads up- the stock subwoofer signal is jacked up, we ended up using the full range signal you get from summing the front doors and dash speakers, with some tweaking to bring out the lows- even on the subwoofer frequencies there is a slope cutting out the really low frequencies and just boosting the signal above 36 or so volume (after that, square wave). The clipping point for the rest of the channels was around volume 50 or so. The other nice thing about the helix was a separate Bluetooth module, everything I listen too is off of my phone and I don't even have to mess with the stock radio. I have everything tuned for it, I just never use it because the Bluetooth is a much less molested signal. It also has a digital in, but I've never used it. The Bluetooth codecs in the DSP's are better than what is in the car, if that is how you are going to listen anyway. I spent a ton of time researching the way audio is done in this car so feel free to ask any other questions, I think I have the amplifier service manuals somewhere as well, but they may not be for your model as Lexus did changes through the years. They also use some MOST-bus that no one has made an integration for, something that would simplify the process immensely (even custom, high-end integration manufacturers don't touch this particular system).
Old Oct 23, 2023 | 11:16 AM
chp7932's Avatar
chp7932
8th Gear
Ok, after your last reply, I'm rethinking the whole thing. Now I'm thinking I have 2 options: use the stock amp and just upgrade the door/dash speakers, add a subwoofer with a dedicated amp and call it a day or go all the way with the DSP. As far as source goes, I like the quality of CDs and I'll use my phone, BT and connected to the USB in the center console. Do you have an iphone or android? Your thoughts on my options?
Thx for being willing to help with this.
Old Oct 23, 2023 | 11:52 AM
swfla's Avatar
swfla
I had an ES350 with standard sound. I upgraded the dash tweeters and put in a powered sub in the trunk, 10" 300 watt Rockford. As we age, high frequencies require to be boosted. This made me very happy. In my younger days , I would have done what you're considering. Perhaps starting with tweeters and a powered sub is all you might need. Just something to consider. I use my iPhone and streaming music apps for my source via Bluetooth. There's also an audio in plug in the center console.
Old Oct 23, 2023 | 02:23 PM
Vtallysx4's Avatar
Vtallysx4
I would go with a good DSP and do it up, my original plan was similar to yours (except I had a DSP laying around) until a local installer (arguably one of the best in the country) suggested the helix as it has the channels I needed and DSP as well. I went all out within my budget. It's not too bad a job. The front speakers are one piece, but luckily the grill can be removed and the metalesh will remove and you get a really nice place to mount your front speakers. You can mount from the bottom and hide them behind the grills as well, I did that at first and finally 3D printed the backing. The tuning in the Lexus system isn't bad, it IS tuned to the car, just no where near as nice as the mark Levinson. I would vote DSP if you have everything else and you don't want to go all in one, the difference is definetely worth it over stock. You can maybe leave the processing alone for the doors and dash and see how it goes. A few pictures of my install- I use the HELIX to control the audio off of Bluetooth sound but when I turn up the stock radio it automatically switches over without issue, when I get a call too. I believe the stock system is set as primary input and when it senses signal it switches to it, so if I want to listen to the radio I just turn off the Bluetooth music and raise the volume on my radio. You can go without something like this if you are fine with the signal from the stock H/U. It's really not bad at all once tuned, probably unnoticeable except for the highest quality tracks. Don't let me discourage you, I'm glad I can share what I ran into and hope it helps.
Old Oct 23, 2023 | 03:35 PM
chp7932's Avatar
chp7932
8th Gear
Thank you for all that. I like your install but the guy, and store, that did my competition vehicle, are both gone and there are no similar (quality) replacements. I'll keep everything under the stock grills and start with just an aftermarket 8" free air sub, maybe some decent speakers in the front and see how far that takes me. Speaking of which, do you think the stock amp would drive an aftermarket free-air 8" in the rear deck?
Old Oct 23, 2023 | 05:40 PM
Vtallysx4's Avatar
Vtallysx4
Honestly I'm not sure, I'm looking at the years and I believe your amplifier is different. The schematic I have shows my amp as putting out 22 Watts Max per channel (schematic literally lists that for ALL channels, including sub), it doesn't have much for information as to what it is actually rated at for the subs. It didn't top out too high on the oscilloscope. Play a note at like 50 hz and grab a volt meter and see what the voltage to the sub tops out at, then enter into one of those online calculators. It might help determine what you can power.
Old Oct 23, 2023 | 06:03 PM
chp7932's Avatar
chp7932
8th Gear
Understood, thx again.
Old Oct 23, 2023 | 09:04 PM
XF40FSPORT's Avatar
XF40FSPORT
I added an all in one 10” Rockford Fosgate, purchased from @swfla about a year ago. With the rear armrest door open, it’s plenty for my taste. I tapped in the signal from the stock sub, & have them both connected.
After the sub install, the stock speakers was lacking power & clarity, so I swapped out the L and R dash speakers with 3 ways powered by the stock sub…still was lacking what I was looking for, so I added an amp to power the dash speakers & it finally satisfied my taste.
I was planning on changing out the front door speakers & rear speakers too, but just swapping out the dash speakers was plenty for me.
I created a thread about my install & all parts used. Just search under threads created by me to locate.
Btw, mine is non ML. Having an upgraded sound system wasn’t a priority for me when I was in the market for my LS, but in hindsight, I should’ve, so I wouldn’t have torn my car apart installing everything. Lesson learned.
